Replacement Crystals for panerai sub (without distortion?)
jjf887
Hi there,
I am wondering if anyone knows where to purchase replacement crystals without any distortion (fisheye effect) for panerai subs?
specifically, I am looking for a replacement for my panerai 682/683 (42mm) thanks!
Reactions: bellfortssss
Gtmatt22
317
160
I can't help but have a similar need for my pam 605 luminor
Sent from my Pixel 6 Pro using Tapatalk
john doe iii
295
90
I have 2 but not sure if they will fit. What size crystal do you have?
jjf887
Bumping to see if anyone else can help?
Does anyone know the dimensions of the crystal ? I spoke with a few companies who asked for the dimensions.
thanks!
keyboardhero
10/12/21
Anyone know what is the dimension, or who/where can I get a non-fisheye lens crystal for pam 979 please?
patnaboy
1,502
4,803
I am unsure of the accuracy of my Vernier caliper but I am measuring 34mm diameter, 3.5mm thickness. This crystal is from a Pam719 which should be the same as a 979. However, please don't quote me on this. The whole crystal cost and AR coating gets pricy so I dont want someone to rely on this info. if it may be erroneous.
Please note the same crystal also fit my Pam508. However, I am noting that previously a member raised the same question at the link below and Prof told him the dimension was 33.5mm instead. I am not sure if this means a thicker gasket? Best to double check with Prof.
Here is the link:
Here is my 508 with a distortion free crystal with Prof AR Coating:
