Replacement bezel gasket for ARF 116610 sub
itwastyped
I removed the bezel on my ARF 116610 and haven't been able to get it back onto the case. I think the bezel gasket somehow got stretched out, and I can't fit it back into the retaining ring. Are there any replacements that would work for this?
I found this but not sure if it'll work
https://www.ebay.com/itm/5-WATCH-BE...UBMARINER-CERAMIC-116613-116610-/161620824457
Sent from my SM-G935T using Tapatalk
37,544
80,338
I have a pack of those and in my experience they got swallowed completely by the bezel groove and were useless. They are too thin in height and width (diameter is OK). What you can do is boil some water and put your ARF gasket in for about 5 minutes, it will shrink up and go back to close to its original shape and size.
itwastyped
I actually saw your original thread about that and tried it, unfortunately it didn't shrink enough so I think it might've stretched out too much
37,544
80,338
You can cut out the worst part. The gasket will work with a portion missing. It will even work in two pieces, but try to keep as much material as possible.
37,544
80,338
BTW rep bezel gaskets usually have a stairstep profile on the inner side where it contacts the retaining ring lip. Examine it closely because it matters which way it goes. IIRC ARF gaskets go "bottom step" toward the insert. The bezel gets held more tightly against the case depending on the orientation of the gasket. If you get it on and it won't rotate or it's too tight, flip the gasket to the other orientation.
DirtyArty
98
34
It has a lip, make sure you’re putting it the right way
Reactions: KJ2020
vkhaa
49
I have exactly the same problem and soo frustrating. Some youtube video make it look dead simple off and on in single attempt. I then tried it just to find that i cannot install the same bezel ????????
did you get to install the bezel in the end?
37,544
80,338
itwastyped
I think mine got too disfigured to use, even after I tried boiling it, so I still can't put it back on
I saw someone mention these gaskets in another thread, but can't confirm whether they work or not
https://www.amazon.com/gp/product/B07D6T2YJN/ref=ox_sc_saved_title_2?smid=A1S5FZX2RI421&psc=1
37,544
80,338
ROSUMI
45
37,544
80,338
Just an update guys, I made some. I will be listing them for sale if anyone is interested. This is one I made for my 126610lv VSF
BZBxcM8
https://ibb.co/BZBxcM8
It's great that you were able to make these. 3D printer? Maybe you could make some for the slightly smaller 116x bezels too. A little better pic of the one installed would be appropriate.
Watch9194
17
I actually made it first for the 116610 model and then tweaked it to work with the 126610 model.
My VSF 126610 is now repaired. Now that this is tested I will be offering these up for sale soon
https://ibb.co/5kwwmhF
Reactions: KJ2020
