- 13/5/16
- 440
- 101
- 43
I have an older IWC rep, I believe it's the ref. 3717 which has a smaller case size than its successor (42mm). The 7750 has gone wonky, as they do, and getting it serviced costs more than it's worth.
I inquired with a TD about a replacement movement that would have the same subdial & day/date layout and he recommended the 7750 from a ZF Ref. 3777. I know the case size is larger on that watch but I'm assuming the movement is the same size. Prior to purchasing I wanted to inquire for those in the know whether this would slot in and be as simple as a dial and hand installation on the new 7750. I've attached some pics of my movement plus the new one from the sales link at Trusty.
Thanks in advance for your knowledge.
IWC0339 - IWC Pilot Chronograph Ref.3777 SS/SS Black ZF A7750 [IWC0339] - $368.00 : Trusty Time Watch, Your Trusty Watch Shop
Trusty Time Watch IWC0339 - IWC Pilot Chronograph Ref.3777 SS/SS Black ZF A7750 [IWC0339] - ZF Factory Top Edition in SS Bracelet! This is V2 Edition Special Upgrade! Made with a Genuine watch as reference! MOVEMENT: Asia 7750 Valjoux Automatic 28800bph with decorated Rotor CASE DIAMETER: 43mm...
trustytime88.io
