Hello, I have a ZF pelagos and there are a couple problems with it now.... I am wondering if there is a way to have it repaired or if it's really not worth fixing this watch let me know. When I rotate the bezel when it gets about 3/4 of the way around it does not click smoothly and is binding, also it has a bit of play in the rotation where it can turn backwards. The second more major seeming problem is that it will stop ticking even though it is on my wrist for a period of time the power reserve is not run out. If i give the watch a little bit of a smack it will start ticking again. It will stop ticking every 30 minutes to an hour.
I know this is a rep and that it is not the same reliability as the gen watch but I was hoping to get a little bit more of a life out of the watch as I've only had it a number of months.
