Repair or Replace?
HPoirot
484
Recently i dropped my h factory 111M, and the second hand fell out.
Must have f'ed up the keyless works too, because i can't adjust the time anymore.
Would be cheaper to replace the damn watch or send it in to one of our watch makers to fix?
COLDI
9,734
126
Just reissue it should be around thirty dollars.
chromed.
2,460
u cld diy, if u think u can manage.? plenty of ppl here who can help advice..
just my 2 cents.
crazyfastbeats
245
Keyless work is an easy fix if you know how to remove the hands and dial from the movement (there are DIYs of this on here or RG). The seconds hand can be easily be reattached, but make sure the stem that it attaches to is still there. That stem is very fragile and can snap off upon hard impact.
HPoirot
484
i tried to diy, but i can't even get past the first step, which is opening the caseback.
Is there anything at home i can use for that?
I'm also not a modder so getting a pam caseback tool would be kinda silly.
