- 1/5/20
- 400
- 117
- 43
Hello My dear Replica-Aficionados,
I have a problem with the Strap/Clasp of my Noob Yachtmaster 116655. The Oysterflex-Strap is attached to the Oysterclasp via a small metal-segment. The segment is attached to the clasp via a springbar, while the rubber Oysterflex is attached to the metal-segment with a screw. You can see this on this pic:
I can’t unscrew this screw. I guess the thread might have stripped. Since I need to change the Oysterflex for a smaller one I have to remove the screw and put it back in afterwards.
Do you have an advice for me? Can I fix the thread? Is there a sparepart for the small metal-segment avaiable?
Thank you in advance!
Best Regards.
Gesendet von iPhone mit Tapatalk
Best Regards.
