Removing and installing ceramic inserts
Pelagic
872
570
Recently had a few members ask about pressing ceramic inserts that are gen construction so took a few pics and I’ll explain my process.
I’ve done a few gen assemblies this way. Cross my fingers I haven’t cracked one yet. A bit of a pucker factor at first but each time went smoothly.
I’ve as well done some ARF as they are gen construction. One of the DSSD inserts I’ve removed and pressed was glued to the metal base ring.
The sd43 I’m picturing here was not glued to the ring. I pressed a full gen sd43 bezel assembly and it is the same as ARF.
I used a razor exacto style knife to separate the metal ring from the bezel. It is important that you wedge the blade between the ring and the base of the bezel rather than between the ceramic insert and bezel ring as it will crack it. The metal base ring acts as a support for the ceramic insert.
https://uploads.tapatalk-cdn.com/20190926/920f99a245dc1cf8795c6387df12202c.jpg
https://uploads.tapatalk-cdn.com/20190926/94b4027e0f16867cf97777be73a7840b.jpg
Once separated you will have the bezel support ring and insert.
https://uploads.tapatalk-cdn.com/20190926/50358a38c18bd374e2b56e462f6f5b18.jpg
Installing the insert the base metal ring will sit in the bezel without pressing.
https://uploads.tapatalk-cdn.com/20190926/2495c4949562f7d6aba9f75f346d4d9b.jpg
I used a junk die and notched out where the pearl is on the insert. Putting pressure on the pearl will instantly crack the insert.
https://uploads.tapatalk-cdn.com/20190926/c84413b62e1c26a96462cd2e0e43d969.jpg
When pressing I used a screw down style press. This allows you to press slowly and evenly. You will hear a snap when it seats. I crapped my pants the first time cause I thought I snapped the insert but no crack nicely seated insert.
https://uploads.tapatalk-cdn.com/20190926/673d5ae04c60a595bb380d074e9843a7.jpg
Complete
https://uploads.tapatalk-cdn.com/20190926/2e882748ab7a050167e53bbab97e78ce.jpg
Here is some pics when I built a franken sd43. I suggest installing just the bezel first so you can align the pearl at 12.
https://uploads.tapatalk-cdn.com/20190926/ddd704c3d9d8567c7cd9a2dd069eabb5.jpg
https://uploads.tapatalk-cdn.com/20190926/de406c554458178d47614a4337e91caf.jpg
Raddave
Administrator
24/12/11
67,017
18,810
Very helpful information here !
Thanks Bro
RepC
204
110
That’s nice to see up close!
Verzonden vanaf mijn iPhone met Tapatalk
mega12
2,537
977
Very nice write up man. Many thanks.
I cracked dozens of inserts and wanted to stay away from them, but after your write up I will try again with a screw down press and to remove inserts between the insert ring and bezel and not touch the insert itself. Two very helpful recommendations. Thanks
Reactions: KJ2020
Pelagic
872
570
I have another possible process in the works. Hard to explain, but I think this is the way Rolex does it.
Making a die in theory will press the center of the back side of the bezel, the other side of the die will be the diameter of the bezel. While pressing the center of the bezel it will slightly torque/bend the bezel outward and the insert will fall out. Also working on the reverse process to press the bezel in without any stress.
This is all in theory. I haven’t personally seen the Rolex press but I imagine this is how it is.
Reactions: KJ2020
37,544
80,327
Looks promising bro. I love seeing new ways to build our toys!
mega12
2,537
977
I don’t get it 100% ;) but assume you are talking about removing the bezel again?
There is very limited area, where you can „touch“ the bezel from the backside. But probably yeah, there must be any tool / die or whatever either to push or pull it out. Can imagine that Rolex uses knifes to remove them :)
5digit4ever
812
1,022
Good stuff here! Just now I realigned the insert on my zzf v2 114060 (it was a half click off). Besides this thread I couldn’t find a good tutorial so I probably should have done a good pic tutorial, whoops. Anyways here’s a before and after shot! Cheers!
brokeAF
81
20
So. Cal
for people that dont have the screw down type press, are there other ways to split them?
Sent from my SM-N975U using Tapatalk
Slugger
Absent Minded Professor
2,217
1,846
On another thread, I read about using a plastic shirt collar stay to release taped or glued in inserts. I thinned the working end (the tapered end) to get it between the insert and bezel and it works like a charm with zero risk of scratching anything.
RyanEdwards
33
Hi would any one be able to suggest a good glue to re glue glued insert for GMT master II. I didn’t realise it was glued when I removed it!
Raymond
279
99
Complete
Is this sub from the clean factory?
