so do you recommend installing the vr3135 ?I dont think its the case. The vr movements slot straight in. This issue has been brought up before
This is a good suggestion. I did it on a RAF dial with a VR movement, so it could work for you. Interesting that the dates are the same, good for the comparison:Maybe try to bend the dial feet a bit. It helped with my 16610 frankens (using vs3135, gen DW and ARF / gen dial).
Yes it is, dial opening is slightly larger than gen, see this post: https://forum.replica-watch.info/th...esnt-fit-st16610-case.10829753/#post-10830925I believe the case is slightly larger than the gen
