Radomir Lug Problem
jblair083
103
I'm having trouble with one of the lug end pieces on my Radomir. Went to change the strap. When I tried fitting the new strap, one of the lug pieces (the L shaped thing) will not stay in the hole. The screw does not seem to grab the notch. Anyone had this problem? Any idea how to fix it? Watch guy says crazy glue or other glue wont hold. Thanks.
kaniel
941
14
Some radiomirs have problems qith the lugs.
Normally the problema is that the screws fall down easily and that's why people tell about putting some glue.
But what you say is different... It's not posible that the lug doesn't stay in the hole. You should try harder or something because the lug MUST stay in the hole and screw MUST grab the notch of the lug.
If the screw falls just put some glue. But before that the screw should grab the notch of the lug.
ALE7575
Section Mod
19,846
423
Maybe you have damaged the thread introducing incorrectly the screw in the thread and then the screw doesn't reach the final point. If you have not forced the screw perhaps there is solution and you can try to place correctly the screw and try again the tightening. It is interesting to change of screw to do it.
ALE
spdu4ia
470
Make sure when you put the bars in that you pull them out a mm to engage the notch on the screw. If you push it in until it stops the notch will be in too far.
nlnlnlnene
1,491
One thing you can do is just put lots of loctite everywhere into the hole.
