Radiomir RAD straps for deployment buckle
pdnb
245
HI All-
From a first glance, I couldn't find any 3rd party straps for 45 RADs fit for deployment clasp. The OEM is a 27/20. Most 3rd party straps for deployment are for 44 Lums.
Any insight besides the $600 OEM solution :D
I am looking for a match for my 183H Davidsen, Thank you!
hooligan
8,332
The OEM is a 27/22. :wink:
Try HKTan or SMAT/Walter. They are both in the straps "stickied" thread at the top of this forum.
pdnb
245
Thanks will check the stickys out. The paris company has a lot of options nice, but a little out of my budget 160 Euro. It is still not clear where to get the deployment clasp itself since the rep clasps seem to be only available for LUMS 24/22 or 24/20. As it been said, the 45mm RADs are 26/22. Why does the width between the lugs important for the deployment clasps? I understand the the taper of strap will be different if is 24/22 vs 26/22, but does the deployment clasp sit on/around the strap where it is tapered? Sorry for the confusion.
hooligan
8,332
Any 22mm deployant should work with your Rad, so no worries there.
Personally, I prefer tang buckles, especially on "Historic" Rads, but that's just me.
pdnb
245
i agree it would be more true to match a historic with a tang, but I am use to bracelets, so I need to be broken in to all these straps!
