Quick Release Advice
ci1031
230
I just received a PAM329 from Lay. It has the quick release function on the case and I want to remove the bracelet to fix some of the sharp edges and oil it. I thought it would come off fairly easy but when I use a pin tool to press in the quick release button, it does not seem to release the bracelet end link.
Has anyone done this that can give me some advice here? I don't want to break anything....
frigpig
Ghost of Sales Mod Past
7,845
81
Are you then pushing the pin out from the side?
madcatlancelot
1,876
108
Here's a youtube video that I watch to learn how to use quick release button the first time.
Disclaimer: Not my video, i just googled it. :)
[ame="http://www.youtube.com/watch?v=xsu1jvnImN8"]YouTube - How to Change Your OEM Panerai Watch Strap to Aftermarket Watch Strap[/ame]
ci1031
230
cool, thanks guys. I just wanted to make sure I was doing right and not forcing anything. I was able to get one side, but the other is not releasing very easy...
ugoderosa
541
The quick release buttons on the current version of the 1950's cased 312, 328, 329, etc. series are really, really bad. The gen Panerai video posted above is fine, but the problem is, the rep buttons are notoriously sticky, whereas the gen version push in like butter. The only way to get the bar out is to put the watch on a very soft surface (like padded carpet for example), then, while pushing really hard on the quick release button, also be pushing out the pin through the hole on the side of the lug with a spring bar tool (the needle nose end of the tool, or if you don't have that, straighten out a metal paper clip and use that). It might take alot of pressure (I have had two of these models, both with bad quick releases- one side worked fine, other was sticky). Once you get the bars out, just put them in storage. Go to panatime and purchase the faux screw-in bars (they have notches at the end, which makes them look like a screw-in type, but they are actually spring bars). Use these bars going forward. Life will be much easier.
