Question on Replacement Bar Pins/Tubes for Straps
jpohl402
5,327
17
If one purchased this package:
http://www.panatime.com/24rebafornep
Do you also need these tubes: (to leave in your multiple straps??)
http://www.panatime.com/24stst316tus
My rep alligator strap came with the pins obviously but also a set of tubes in the strap. What are the tubes used for??
What if you don't use tubes ??
BTW: that rep gator strap was so terribly stiff after putting it on WAY loose on the 2nd buckle hole, I couldn't bend it enough to get it off myself and wore for about 30 minutes until I could have a friend press down hard enough to loosen it up and pull the tongue out. What a nightmare - guess what already went in the trash
cwazy1
3,812
tubes just make the stress distribution even across the strap... I honestly never bother with tubes.
tootall
Vendor (Strap Maker)
2/5/06
1,343
I once had a long discussion about using tubes vs not using tubes. It got out of hand, but the conclusion for me is that it is personal preference.
trailboss99
Head Honcho - Cat Herder
Administrator
43,647
17,457
Trusted dealer Watchbitz also has a full range of pins and tubes, just contact Offshore via PM as they can be mailed in a letter a lot cheaper than the site will show.
Rogerthat
919
I don't think they do much personally
Used to not bother but later changed my mind and bought a bunch of tubes and now use them all of the time
The cost is not much so I figured I might as well use them but would not consider them required
the_don_robinson
325
I like the tooobs. Gives me some assurance that the screw is going in straight and not distorted etc.
Sent from my BlackBerry 9810 using Tapatalk
spdu4ia
470
How often do you wear your watch with no strap on it at all to see those scratches?
