Question ARF Bracelet / Clasp Code
Gioz
151
Hey Guys!
I ordered a ARF Bracelet ,there is a E5N as Clasp Code..do you know if it is compatible with my vsf 116610 submariner?
weezkid
1,665
1,128
Lane Cove
Gioz May I ask who did you order this from? I am looking for one to replace my VSF bracelet. Thanks in advance!
Spiral_Cabbage
462
140
Conus
I had an ARF bracelet that fit on my VSF, but looked awful. The SELs were almost flush. I went back to the original bracelet and never looked back.
I heard the same from others but also that it has worked for others.
Good luck.
Gioz
151
Good luck.
The glide lock is better on ARF
Spiral_Cabbage
462
140
Conus
The glide lock doesn’t make a difference if the watch looks worst. Unless your in the habit taking of playing with the clasp.
the glide lock on my vsf is just as smooth as the arf.
Gioz
151
i dont question about smooth but on arf. logo is better and steel is 904 L and in the vsf not
Reactions: Repwearer1981
Spiral_Cabbage
462
140
Conus
Your question was if the arf bracelet was compatible with the VSF case. In my experience it is not. Your question was not if the clasp was better, which no one would notice. But they sure would notice the flush sels.
Also, if you already purchased both, why not wait and see.
good luck.
StreetFighter
Insert Coin
4/9/20
2,880
3,470
I have ARF E5N links on my VSF. One endlink fit is crap. I didn’t use the clasp as my VSF clasp was better. The endlinks themselves are better cut than VSF’s, yours may or may not be, these are inconsistent.
Gioz
151
clasp lock on ARF is 904L and on VSF for sure it is not
