Question about Panerai clasp width
Manray
575
54
Hello,
Does anyone knows the strap width required to mount a strap on a Panerai deployant clasp?
I am not sure if it is 22mm or 21mm.
celestial
29
It could be either. So it'll be easier if you can actually measure it. Do you have the clasp already and are look'n for a strap for that?
Manray
575
54
I am looking for a clasp so I can make a strap an test it.
mysterio
9,794
864
Well the width of the strap that passes through the deployment can only be 22mm wide. then expanding to 24mm or 26mm for the lugs.
Manray
575
54
So it is always 22mm or it can also be 21mm as mention in the previous message?
celestial
29
My bad. Yes, for GEN deployment clasp, 22mm is ALWAYS the case. However, there aftermarket deployment clasps w/ 20mm width. My apologies for the confusion.
