Hey fellow BBers,
Was able to find a Black BP FF Noob with TB, but from one of the newer batches. I know the v1s hit it out of the park, but from my recent reading it seems like the v2s / v3s have been going downhill from a QC perspective. I'm hoping I'm a bit lucky with this one.
Overall, I'm a bit unsure about the font color and some of the font spacing. This may be due to camera tricks though. Do you guys / gals think this should pass?
Here's my stab at the QC, but this is my first rep assessment so I would welcome any thoughts on what I missed!
Assessment:
- From this face, the teeth count seems right at 12 between the two lug ends where it meets the case.
- Finish looks great, and I understand why this rep got its super reputation.
- The hexagonal shape in the lug bar seems a bit shallow vs. the gen pictures (they seem deeper, and from an angle appears to be a hollow bar) but I know this was a weak point of the rep. I may replace them with spring lug bars anyways...
- Lettering seems in line with the gen pictures, similar width and depth
- Bezel height seems to tie with the gen pictures
- Crystal thickness seems to be SLIGHTLY flatter than the gen pictures by 1/2 a mm at the top of the dome
- The font seems a bit more white than the v1, and the gen, both of which have a slightly more "creamy" yellowish tint to them; not sure if it's just the bright white light of the room throwing it off though
- The numbers seem to align with the tick marks as per the gen, with the line slightly above the 2 in the 12, and the 6 dead center...may be the camera angle but the 3 seems like 1/2 a mm too high
- Arm length and shape seems quite good
- The bezel doesn't seem perfectly centered...like it should be adjusted 1/2 a tick clockwise; note the bottom tic and the 6, and the top diamond vs. the 12; is this a camera angle issue?
- Any thoughts on the coloration? I know this one isn't as complicated as the blue, and there doesn't seem to be color differences
- Logo on the crown seems correct
- The slight indentation where the lug arms join the case match the gen pictures
- Seems to have plastic wrap, but looks like the back of the case is the same polish / texture as the rest of the case...gen pictures seem to vary from having a more rugged concentric circle to the polished texture featured here; watch may need some elbow grease and a polish cloth when it gets here
- Text font - Antimagnetic the C seems to go a bit further out than the gen by 1 mm, stopping more on the O vs. the end of H...camera angle issue?
- The back of the case font doesn't seem as crisp / deep as the gen, or even the v1...not sure if this is the plastic case making things a bit fuzzier?
- The lume seems weak vs. the gen and the v1...does this watch need reluming to make it superlume? The lume also seems a bit more yellow / green than the v1 and the gen.
Phew, that was my stab at QC. I appreciate any thoughts on (a) where I got it wrong, (b) whatever issues I'm missing, and (c) whether or not this super rep passes QC. Nonetheless, it's a gorgeous looking rep and I look forward to having this hefty beast on my wrist. Thanks!
Assessment:
