Pugwash's IWC Aquatimer 2000m review
pugwash
7,211
40
I got my replica IWC Aquatimer 2000 from Precious Time in the UK. If you need one of these watches, and I can see why you would, drop him a line and tell him I sent you.
In 1997, IWC replaced the Ocean 2000 diver's watch with the GST Aquatimer 2000. It was slightly larger at 42mm diameter, even though it housed the same 2892 movement. At 14.5mm, it was also quite thick, but this was to be expected in a dive watch, especially one designed to withstand ther pressures that 2000m can force on a watch. Available in stainless steel and titanium, and possibly gold although I've never seen one, this was officially part of the GST line, hence Gold, Steel and Titanium. The unique design points were the screw-in crown that was robust even without crown guards and the bezel that required two points of force applied to the front before it would turn.
The replica, however, doesn't have the unusual bezel mechanism, settling for a more traditional one-way click system, much like the more familiar Rolex Submariner or the Omega Seamaster. The inked inner bezel is also of much lower quality than the original, but I'm working on colour-matching the paint from the original with a dark-grey acrylic paint.
The movement is equally different, housing an ETA 2824 instead of the more costly ETA 2892. This isn't really an issue as the 2824 is a solid and respected movement that's both cheap and reliable with spare parts available to any watchsmith with a wholesale account.
The main difference with the replica though, is the size. The replica is 3mm deficient in the diameter and xxmm thinner. While this obviously doesn't affect its useability as a watch, it may well signal it as a replica to the more observant of IWC fans. Unfortunately, there is no titanium replica available.
I feel I should also mention that the crystal could really do with an Anti-Reflective coating if this watch is to be your every day watch. While it is perfectly readable, it is slightly milky from certain angles.
This may seem like a negative review, and it does indeed read like this, however this is one hell of a watch. Most people wouldn't be familiar with IWCs, let alone discontinued models from the late twentieth century, so the chances of being called out on this are minimal. It's got a solid ETA movement, a superb case design and one of the best bracelets in the replica watch game. While the clasp is prone to looseness, I believe this is just on my model and is not a design flaw. I'll know more once I've taken my rat-tail file to the parts.
All in all, this replica watch was released very quietly and wasn't popular at all, due in part to the bezel printing and some misaligned 12 o'clock markers on the dial. However, I still think it's a decent watch and you should consider getting one as it's a much nicer design, in my opinion, than the Ingenieur.
ps: No photoshop on the pics, just pure iPhoto.
takashi
11,500
11
At that time the focus is on IWC GST Chrono Ti replica. This one tends to get overlooked due to the flaw you've mentioned.
By-Tor
2,288
34
Great review and pictures. It's a pleasure to read stuff like this... and I learn more about IWC every day.
Yeah, when this rep was released many members said that they're "going to wait for the next version" (because of the flaws you mentioned). I'm pretty sure there will never be another version.
Nice watch indeed.
acidzerocool
620
Great pictures and great review Pug. Thanks for taking the time to educate me further on the rep of this watch.
Nice piece....
longshot
131
damn you and your pictures pug :lol:
i had the white dial version and liked it a lot but it had problems. the crown was too long and would not screw own, but my biggest issue was that the 12:00 indices's were not parallel or even or straight...
looks like you either got a really good one, or they fixed the problem!
thanks for the great review!
chrono903
Great review. It turns out IWC had initially wanted to use the 2824 for the AT movement but had issues with it's thickness and settled for the 2892. The first models used both tritium(on the 12'oclock indice and hands) and Luminova(elsewhere on the dial). That model read "T Swiss Made T" across the bottom. Eventually it was changed to all Luminova. Those dials are marked simply "Swiss Made". There was a transition where the all luminova dials lacked the "T" at the 28 and 33 minute mark but still had the shortened indices none the less.
Thom
pugwash
7,211
40
Entertainingly, on the gen GST Chrono, there are some marked T that don't have tritium as the text was printed on the rehaut and the watch fell directly in the middle of the transitional period away from Tritium. :D
chrono903
cool! so there are four dial variations. And I was thinking, GST-gold, stainless, titanium, The hands and indicies on some models are gold.Perhaps that fullfills the G requirement.
Thom
hava
76
22
hi i have one but the bezel is bad painting
Hi i buy one, when arrived i saw that the bezel is very bad painting. Any have painted it or fix it ?
thanks.
higgy
3,410
Nice review Pug..... :wink: I'm sure sales of these will be on the increase!!!!!!!! :D
Higgy 8)
pugwash
7,211
40
If not, go see Precious Time and buy one of these. :D
lincoln
29
Have a friend with a gen IWC and he's had trouble with his clasp as well. IWC ended up replacing it rather than repairing it. I'd be interested to hear how you go with fixing it yourself.
