Project Rolex MilSub 5513/5517 Finished Pictures
don9998
19/9/09
Hello to all. I am a lurker around this forum, this is my first post.
It's nice to meet all of you as well as viewing many of the members excellent projects.
This was a very special project for me that I have been wanting to take on for about 5 years. the timing was never right and this project just kept being pushed back and back etc..
I have few vintage Rolex's in my collection. All of them are Gen, This goes for all of the watches I own.
I have seen few posts here of members who have built their own custom Rolex Milsubs with ETA movements that are actually very nice.. The only thing that bothered me is that the cases and movements were not rolex original.
I mean who in their right mind would hack up a real Rolex 5513 to create the ultimate 5517? Well that person would be me.
For awhile I was set out to find the right vintage 5513 rolex with strong lugs in original condition with a strong rolex powerhouse 1520 caliber.
I finally found the right one and the project began..
I have been working with watches for some time, I have many tools, most of them being the finest bergeon tools you can get. So I advise no one to try this themselves unless you have much experience. Otherwise you could end up with a few thousand dollar rolex you have to toss in the trash.
First, I did a lot of research to see how I would set out to do the fixed bars..
I contacted member Bonesey for some advise on the fixed bars so special thanks to him for taking the time to give me some info. Standard fixed bars for Rolex Milsubs are 2mm. I decided to go with 1.8mm 316L stainless round bar as I did not want the bar to intrude too much into the chamfers and would ensure the case could handle many years of polishing's and abuse without the Lugs being compromised from the metal getting too thin on the outer lug area. that .2mm makes a big difference.
anyways, after dropping the movement from the watch, I began to hand drill the current spring bar lug holes to the desired 1.89mm. It's important you drill the holes out perfectly straight or else you will end up with uneven holes..
finished fixed bars
I then gave the lugs a polish as I like the high polish look some of the vintage milsubs have. After the buffing out the watch but keeping some of the light marks and dents as character, I reinstalled the movement back into the watch. You can see the original tritium glossy dial with WG surrounds and matching tritium hands.
As you can see on the side of the lug, the fixed bar is pressure fit into the watch case. No epoxy, or weld was used. The bars were pressed into the case and are not going anywhere.
Next I set out to find the right right Dial and hands. Many aftermarket dials I have seen from many different company's did not have the right font on their milsub dials.. Either the font was too thin, or not placed properly and some, the markers did not look accurate.
Now this watch was not made to try and fool anyone into thinking it is real. This was made as a fun conversion keeping it as rolex original as possible.
I knew this would be such a fun watch to wear and to have without paying the 100k price tag, it will pretty much be the same as the real 5517. All the MOD did was get batches of rolex 5513's, they would mod them added fixed bars in the same way I did, they would print up aftermarket dials and hands and bezel inserts and swap the parts, then DONE. A military spec rolex.
anyways, after a long 8 week battle with a company I will not name trying to get the dial which I special ordered with just a couple small changes to my request. The dial markers are inactive and do not glow. They have a nice cream patina. The hands were ordered through a different vendor out of Geneva. I did not want the hands to perfectly match the dial, I wanted them a shade off as the real vintage milsub hands were produced by different vendors than the dials and they age differently causing the colors to be slightly off from the dials in most cases but not all.
the hands I ordered are cream patina. SO... Once I got the dial, hands and milsub insert, I started to install everything.. The insert tritium pearl was transferred from the Gen insert to the new mil insert. The insert I used was not a cheap 30 dollar insert you find on the bay.. it's a good quality insert. It's important you buy a good quality insert because it will snap in the bezel like the Gen's do and hold a strong pressure fit with no glue required. Same goes for the pearl, It will hold the pearl nice and snug like a gen Rolex insert. I spot the inside of the insert with a dab of epoxy just for good measure to really secure the pearl down.
So all and all, the only things that are aftermarket on this watch are the Insert, dial and hands.. Oh yea and the fixed bars of course.. I ordered a brand new gen rolex tropic crystal for this build and installed that as well.
I wanted everything to look very clean.
The dial was a pain in the butt to install. A couple mods had to be made to fit it to the 1520 movement.. I wish it was plug and play but it simply is not.
once everything was installed properly, I let the watch run down for 48 hours.. This 48 hours the watch is considered in critical care, if anything is going to go wrong, it will happen within this time period. I actually had to calibrate the movement to compensate for the heavier hands.. So once the watch was now keeping time like a chronometer should, the gasket was oiled and the case back sealed.
A few phoenix nato straps were ordered for the watch. For most of you who don't know about Phoenix nato's.. They are the exact company that supplied all the nato straps for the British military watches and still do from this day. They are made and shipped out of the UK. excellent straps and I highly recommend them. This was a very expensive project, as well as a real pain, but the finished product is so worth it. This is an Authentic Rolex 5513 converted to 5517 and probably one of the most accurate you will ever see. It was truly a labor of love. I did not want to replicate the army numbers engraved on the case back for obvious reasons.. Dial installed super clean, no dust, no dial scratches/marks, hands are flawless with no marks, installed using nylon tweezers. Any dust seen is on top of the crystal. I'm a stickler when it comes to dial dust or installation marks on the hands.
So enough talk.. Without further ado, here is the finished product.
I hope you all like it and would love to hear what everyone has to say about this project. :cheers:
Blitzgheist
96
I love stuff like this. I'm not a Rolex fan, though lately I have found my head being turned. Anyway, I have a great appreciation of the dedication and work that goes in to making such a beautiful object. Well done sir.
phillycheez
3,063
I'm very jealous! You did a amazing job. Those fixed lug bars look spot on.
I'm surprised you didn't use omega seamaster hands though.
don9998
19/9/09
thanks for the kind words.. The omega seamaster 300 hands don't fit the 1520 rolex caliber so well. Not only that, but 90% of the hands out there for the seamaster are all aftermarket anyways.
To find an original mint condition set of tritium seamaster 300 sword hands with a nice cream patina would be close to impossible and if they were found, you're talking at least $1200 or more for NOS.. current Luminova hands are cheap at around a couple hundred.. but even then, they just do not fit properly and luminova is a greenish color and would not match the dial at all.
So best to go with an excellent aftermarket hand designed specially for a rolex 1520 caliber. no way to tell the difference anyways aside from the second hand being a little different to that of the omega second hand. At the End of the day, the omega second hand isn't even accurate either to the original 5517 sword hands. Although they do look nice non the less.
but believe me, I thought about it.
also a side note to add, This current set of hands installed are actually my second set I went through.. the original set I ordered, the sword hands were too thin.. these new hands that I used on the final product are as good as it gets for this project.. nothing else available that looks as nice or functions as well.
comparison, old hands on the right, new hands on the left.
Wacker23
2,103
Did you show this on rolex forum and the clowns here shunned you? i seem to remember this beautiful watch. Great first post and welcome to RWI.
Mendota
3,220
88
MN
Wow, wonderful work. Nice job with this. I am very impressed. Enjoy it and wear it proudly.
Mendota
3,220
88
MN
Whoa! It's basically a gen.
My sentiments, exactly. For all intents and purposes it is indeed a gen. The only difference is hands and dial. Big deal. Many gen owners of Datejusts who bling their watches out have aftermarket dials. All that diamond crap and bling doesn't come from Rolex - most of it is aftermarket. They even tell the owners not to send the watch into RSC with the dial installed. They give them the original dial back after installing the bling and instruct them to just bring it back to swap in the original dial before they send it to RSC.
I liken this to a car owner who buys a vintage Corvette Stingray. The body and engine are original, but maybe there are some components installed into the engine that are aftermarket parts. Who cares? Unless you are showing it at a strict auto show where you are competing against others, nobody on Earth is going to care.
With a watch like this, I think case, crystal, crown and movement = gen. You aren't selling it as a gen and you aren't sending it to RSC, so it's indeed a gen.
don9998
19/9/09
Thanks for the kind words.:cheers:
that's the problem with most Rep's is after a period of time, they begin to break or things will happen as they are not manufactured in the same way a Gen is, so in many cases, durability can be an issue. I wanted something original Rolex, so it could be strong and have the quality there as well. So by modifying a Gen Rolex is simply just a modded Rolex. Just like "Pro-Hunter" makes custom modded rolex's that many movie stars wear, or project X designs.. They refinish dials and print up their own along with installing fixed lug bars, or DLC Treating their watches..
From a past email to ProHunter, I had asked them if they would ever take a vintage Rolex in for a treatment. They said no Vintage as they are temperamental to work with and if anything goes wrong, replacement parts are not readily available, which is why the only customize current rolex models.
So at the end of the day, all this is, is a custom rolex.
This was a project that was years in the making.. something I wanted to do for such a long time, but kept pushing it off. Finally I put the pedal to the metal and did it. It's just hard to cough up thousands of dollars on a project that you do not know what the outcome will be. This definitely had it's challenges along the way and at one point, I felt this watch was becoming to me what the GT 500 Eleanor mustang was to nick cage in the move Gone in 60 seconds.. It seemed within reach, but every time I would begin work, something would go wrong, postponing the project more and more.
I probably will never do one of these ever again. But, the final product was worth all the time and effort for sure. When you do an extreme mod to a Gen rolex, there are a lot of unknowns along with it, sometimes no matter how much research you do, you learn even more as you go.
The real vintage 5517 milsubs are infact aftermarket as well. Rolex's would supply the ministry of defense aka the MOD with 5513's, and then the MOD would Modify the watches to their own standards. The dials in milsubs are refinished dials anyways, that's why the font doesn't even match rolex's font on standard dials. Back then, that was the best they could match up the dials when re printing them.
So my watch is essentially the same, it's a modded 5513 only it was moded by me and not the MOD department.
My watch is keeping COSC time and has been pressure tested, it's ready for battle I would think. So now I can enjoy this for the next 50 years. I sure know it will stand the test of time because at the end of the day, its a rolex.:cheers:
Mendota
3,220
88
MN
^ So amazingly cool. I love it. I would love to do something similar someday. Not with a milsub but with another vintage piece. I think it would have so much meaning and it would be a really fantastic conversation piece.
I just sent some reputation points your way and I bookmarked this, too, as inspiration for that "someday." :)
don9998
19/9/09
hey thank you for that and for the kind words! :cheers::cheers:
joe_chill
1,274
Very nice! No jealous at all... no... I'm not. Rep added by the way. Welcome =)
mir36
123
A legendary build! Definitely a project not for the faint-hearted or fund-challenged.
Thanks for sharing. And I was one of the quiet guys who enjoyed seeing this at that other forum. :)
