Problem with watch - Warranty
Assphalt
Hi all,
Just a small question...
I purchased a Watch from a trusted seller on June 21st and it broke (a piece is rattling in the case back) as of the 23rd of January...
The seller tells me that they only offer 6 months warranty, and that I would have to pay to have it fixed and shipping both ways.
I would understand if the watch was older but I only had it for 7 months...
Help or input on what I should do?
Thanks
FX
trailboss99
Head Honcho - Cat Herder
Administrator
43,856
19,641
Hey mate. If the vendor offers 6 mths warranty then that's it I'm afraid.
Quite a few offer none at all unless DOA.
Sounds like the rotor has come lose, hack the watch (pull the crown out to the time set position) to stop the movement so the screw can not do damage. It's a simple fix, a screw simply needs re-inserting. If you can get the caseback off you can do it yourself.
cybee
11,134
30
Yep like TB says if you can get the caseback off it might be very simple. Initially I thought maybe a movement retainer screw might have come loose. Plenty of tutorials around here to help you get the caseback off...Good Luck.
killbill
68
The duck tape method is good if you don't have a proper caseback removal tool. I was a bit dubious at first but tried it and it does work.
roll some duck tape into a ball, place onto the caseback, hold the watch firmly, push down and twist.
...unless of course it's a caseback that is screwed in!
Assphalt
Thanks for the replies... I did find a tutorial here that said to use some kind of rubber...It worked
And TB was right it was just the rotor...screwed it back in....closed the case and voila...a 2 min Fix...
Thanks for all the help!
FX
ShiroTenshi
6,805
258
FX
Glad you got it sorted out, continue to enjoy your watch :)
cybee
11,134
30
FX
Excellent and great job on your first repair
ALE7575
Section Mod
19,847
434
CONGRATS !!
for a successful first repair
ALE
