Problem with Panerai Blackseal Movement Swiss 6479
xbaltzx
73
Hello all,
I have not been active on the forum for a while so mods if this is the wrong section please move. I have a problem with my Panerai (rep) Black Seal and thought that some of you guys and gals might be able to help identify the problem.
I have included a video to demonstrate what I am experiencing and also a picture:
[youtube:v73d0rnu]http://www.youtube.com/watch?v=p6dE_rWHLBc[/youtube:v73d0rnu]
http://picasaweb.google.com/lh/photo/tv ... directlink
The symptoms:
Crown will not wind
Crown will not screw back in
Movement does not operate
What I have tried to fix problem:
Release the tension (unwind) on the mainspring
Winding the crown
Do you think that a gear may be stripped?
Could there be a problem with the crown or winding mechanism?
Thank you for any help.
Dan
horologie_unitas
5,148
very tough to say...and the video does not help much.
sounds like a stem / keyless works problem to me.
id take the crown / stem out, clean and lube it.
then try again.
xbaltzx
73
Thanks for chiming in horologie_unitas.
After re watching the video I made, I did not feel it would help much either.
I will give your recommendation a try.
Also, when I try to wind the movement the crown feels like it is fully wound.
mene_menelaou
16/3/09
I think that indeed is fully wound and there is a loose screw in the case (or something else) which is ''blocked'' under the balance wheel and therefore the movement stoped.
I have experience a similar problem in the past with a mounding tube that blocked the balance wheel.
