hi guys, I have found a strange problem with one of my watches with An A7750 P9000 Panerai Decored movement...
I've seen that the rotor doesn't wind the movement because it doesn't rotate properly counterclockwise... as if it was blocked by something, while in the clockwise direction he rotates freely...
in fact it often stop when I wear it... with manual wind it runs strong with a good power reserve...
I've notice one thing... when I open the CG of the crown the rotor returns to rotate freely in both directions, and crashes again when I close the CG...
It is strange..... [emoji19] which could be the cause
thanks
another question... just curiosity...
how can I remove the P9000 Decored rotor form the plate? the 3 screws are faux.... right? so... how can I do?
thanks
Inviato dal mio MicroTac utilizzando Tapatalk
thanks
thanks
