- 17/2/12
- 239
- 0
- 0
Hey all, I just got my 111 v3 noob. The problem is the crown cannot be pushed back to the winding position. After giving it a full wind, I pulled the crown out to the time-set position and set the time. The crown then refused to be pushed back to the winding position. I can push it in but it springs back out and does not wind.
Also, it appears there is a hex nut sticking out a 1/2 mm or so from the case where the stem enters the case. This normal. I can post pics and I'll be notifying my TD too but just want to know if this is an easy fix or something I should send back for. Thx.
