Pressure Test / Water proofing
JumpiterT
148
51
Hi Guys, bought my pam 498 recently. I asked the TD to do pressure test at 30m and at 50m. At 3 bar it has a leak rate of 2.3%/m and at 5 bar it has a leak rate of 3.3%/m. However the rating is a pass. How does this work. I did some googling but didn't really get anything sensible. At 3bar (30m) a leak rate of 2.3% still means that water is getting into the watch ? so how can it pass?
Thanks,
Maron
9,469
807
Canada
I dunno but if you want to trust your watch is safe for water you need to test it yourself or send it to someone and pay $50 to have it looked at and tested
Sent from my iPhone using RWI
bobandshawn
3,439
326
Florida
Interesting numbers. Just yesterday I brought my 5513 to a local shop because they have a dry tester. No numbers - just told me it was pass or fail. I guess I'll have to do some case work and test it wet at home...
B
mysterio
9,794
864
To go into interpreting water resistance measurements would be to dive deep (pun intended) into ISO standards and what not, far too much time to be investing into it IMHO. The % of the leak rate is basically a measure of the deformation of the case against the applied pressure and of course there's a limit, which is different for watch case sizes and of course depth. Ideally it should be zero, but as the pressure inside the watch case is not equalized to the pressure applied to the outside and the watch is not perfectly sealed, that's an impossibility (which is why the term waterproof ceased to be used as there is no such ideal model,eventually at some point, everything leaks). So there is a limit to how much leaking or deformation that can happen in a specific amount of time. That's why instruments such as the one bought by TDs are used, to take the measurement and do the calculations instantly. As much as there is data presented to you, I still would advise you against using your watch in water unless it has been tested at your local watchmaker. I don't think there is a TD which guarantees the watches from water damage, they just do the WR test as an added service, nothing more.
