potential issues.?
chromed.
2,460
i'm almost in e process of overhauling my Pam 111E frm an unknown source( bought it frm a local guy but no idea of the source ).. according to him its a swiss rep but alvinado has comfirmed it isnt..
anw, what are e potential issues i might face taking on this project.? what i feel is tt since e source is unknown, i might have probs fitting dial, movement&CG.. hopefully e most i need to do for e CG is filing it abit so e screws align, right.? my question is, how sure can i be tt e dials&movement can fit.?
here's e list of intended mods:-
- relumed & matte finished dial by alvinado
- movement mod( if e movement's engravings arent stuck on )
- either a Toro or DSN CG
- T43 crown ( if i can find it, sources any1.? :) )
- polishing e hairline scratches cause frm my constant strap swapping ( i have 1 pam with 7 straps )
- either AR removal or a taka crystal swap
- canon pinion mod ( can any1 tell me whether i can just use e rep pinion or i have to replace it.? )
if any of e pam experts here can highlight any other probs i might face, i wld appreciate it :) but other then tt, did i leave out anything, guys.?
Time4Direct
Trusted Dealer (In Memoriam RIP)
2,058
40
Asian or Swiss 6497 parts will swap around so no problems there.
cannon can be used just file back of hands down. just a word of caution though some relumed dials are thicker than factory dials so you may be better off getting a H3 cannon set with hour gear. They are a straight fit.
If you are reluming it yourself take care to not use too much lume or you will have trouble fitting the second hand at 9 if it's too thick
chromed.
2,460
thanks for the tips !! but i forgot to mention i'd be modding it to a Pam 112H :) sorry, robert :) btw, i replied ur post on e cameras :)
cheers.
hooligan
8,332
cus+0m, have you got some pics of this watch?
Have you considered it might be cheaper to sell the 111E and simply buy a 112H rep?
chromed.
2,460
well, quite honestly, i dont wan to but cux this is1of e reps which i bought b4 knw-ing of RWI&i spent quite a small fortune on it.. kinda dont want to let it go to waste&also i'd be suffering a huge lost as i'd prob get only get 1/5 of e actual cost..besides i screwed up e CG..
i figured tt i'd use some of e existing parts&make it right..
how do i post if i dont have a image hosting website acc.?
