Possible to switch 7750+dial from standard 44mm Luminor to 1950 Luminor 44mm?
pacecar2121
117
1. So, is it possible to switch 7750 and dial from standard 44mm Luminor to 1950 Luminor 44mm?
I haven't purchased a 1950 case, yet, so I don't if the internals are the same between the two cases. I'm interested in possibly building a fantasy watch with a 44mm KW ceramic case (1950 Lumior 44mm) and an older Pam dial/movement combo (like the 088 for example).
2. As a follow up, if the above is possible, would the caseback from a noob 088, for example, fit the 44mm KW 1950 ceramic case?
3. If the above two are possible, would an equivalent seagul movement fit and attach in the same 44mm case as would a 7750?
I searched around on the forum before posting but couldn't find a direct answer (or answers). I appreciate any help.
