andreww said:Is your PO an old 45mm or a 42mm? I don't suggest grinding, there is a strong possibility you will just ruin the bracelet.
bme said:andreww said:Is your PO an old 45mm or a 42mm? I don't suggest grinding, there is a strong possibility you will just ruin the bracelet.
It's an old 42mm. Do you know where I can get 20mm end links?
