Ploprof...franken? homage? work in progress? Photos of my Ploprof
dpd3672
1,935
3,232
One of the first things I joined this forum to find was a rep of the Omega Seamaster Ploprof. I soon learned that they're damn near impossible to get...long out of production, only available (rarely) for a few minutes M2M, and with the gen just unrealistic to purchase (I can justify 5 figures for a watch I'll wear every day, but for an obsolete "niche" item that scratches an itch but mostly sits in the box, it's just not something I can do).
This watch will probably be worn for a few days a year, so I don't want to go overboard, just to fill a (to me) glaring hole in my collection of mostly vintage tool watches. When I first started collecting watches, about 25 years ago, I came THIS close to buying a gen more than once, but couldn't convince myself to blow $1-2k (at the time) for such an ugly watch...but the design has grown on me.
There are a couple homages made of the Ploprof (rumored to be made from the same parts) by Steeldive and San Martin (and others), which a few members here, most notably Frank_NRW, have done some pretty impressive mods to approximate the Ploprof. Based on a lot of research, and some recommendations here, I reached out to manodeoro for help, guidance, and a custom dial. He did not disappoint.
There were some delays, some frustrations, and a little bit of rough handling in transit, but I finally managed to put it all together for a test ride last night. The dial had come loose from the feet in transit, so it's attached with sticky feet for the moment (and the date window is a little off), but that will be addressed in the next couple days, once the honeymoon is over, lol.
I also plan on sourcing a sterile case back and having it engraved like the Omega (since this isn't intended to be a 1:1 rep, I'll probably go with either an Omega symbol or the Seahorse or some combination of the two that look vaguely '60s...or just parallel lines, like the original). There's no crown in the traditional sense, so I don't have to worry about that.
Future mods will probably be limited to finding a clasp or mesh bracelet with Omega branding (hello, AliExpress!) and some aging of the exterior parts so it looks like a tool watch that's seen some use. Of course, I'll keep an eye open for a rep to come up M2M (or the factories to start producing them again (I'm talking to YOU, VSF, this is a crown and tube even you can't screw up!), but for now, I'm very happy.
So I'll end this with a thank you to both Manodeoro and Frank_NRW for the help, the heavy lifting, and the inspiration...now to the (low quality, cell phone at my desk) photos.
dpd3672
1,935
3,232
Damn, what kind of movement does that Sharkmaster take? This dial might find its way into one...
thenut
567
555
Swiss ETA 2824 , Case construction is stated 1:1 with the Ploprof 600. Ad a Plastic Pusher and you got the Genuine Look
dpd3672
1,935
3,232
And just like that, my next project appears...lol.
3 Explorers, a 1680, a 5513, and a couple fantasy projects for the gf's Christmas present, and I guess I know what I'll be doing...
Frank_NRW
301
209
France / Germany
Interesting development. I was not thinking about a vintage look ploprof, but this is tempting. I would be worried about ruining the case, but why not ? At the moment my priority is to find a source for ceramic bezel inserts to replace the plastic ones I got.
The next move would be to purchase grey and white dials from manodeoro, the two I already have are a bit dull and need to be replaced at some stage. I'm also looking how I could improve the straps, I have upgraded the original ones to 24mm and am tempted to modify the lugs to go even wider. Like on a Bell & Ross.
Then I could try a bronze ploprof although I'm not a fan of bronze watches in general. But a green dial from manodeoro and a coarse sailcloth strap may do the trick.
Or I go kitch and opt for a rose gold ploprof. if I can get someone to plate the SS case, bezel and crown in rose gold. I would also need a white gen strap and a white/gold dial...many moving parts here, maybe a bridge too far for my skills level.
Any other suggestions ? I know that dpd3672 was thinking about a blue 2023 model.
Considering this is just to kill time while waiting for a proper rep.
Reactions: thenut
