RqThrottle said:
Hmm...not so fast
I believe Davidsen's case is the right one (117), but his dial is far from perfect (lettering too white?). Also, if he puts a swiss movement in there you WILL have a recessed pin problem. Only the CN movements are cannon pin problem-free.
There is some member on this board that did a boatload of research, and bought them all. He said that overall, the most accurate fiddy is ELs swiss one (117 case, correct movement). You will then need to superlume it, fix the cannon pin, and put a Davisen Crystal. ~$700 after the dust settles.
Not quite true... 8)
DSN Fiddy rep is one of the closest you can get these days, I have one so I guess I know what I'm talking about
The only "drawback" with his Fiddy is that it doesn't come with Swiss ETA E-series mov't, but he will install Swiss H-series 6497-1 mov't per your request. This is what I did, and it came with no recessed pin because he fixes it during the install, all included in price.
It glows like a torch, comes with REAL sapphire, A/R coated, correct off-white dial txt, correct e0117 case, and those Fiddy hands of his (short tube on minute hand) are by far the best ones you can get these days...just ask Mark (finepics) or Vacuum. This is what you get for some $350+
I also had Andrew's and Eddie Lee's "the latest/best", and they need extra mod-work (cannon pin / hour wheel fix, short-tube minute hand, dial relume etc). Andrew's come with Hybryd Asian/Swiss E-series mov't, Eddie Lee's comes with the nicest (so far anyway) E-series Swiss mov't.
These will set you back some $500-650, depending on level of modding done to them.
cheers,
babola
