please help me choose - pam 661,pam 504,pam 384
nardin
1,850
81
i did alot of research but coudnt make up my mind what will be better rep.
i love the 384 as gen but i saw the rep is not so good.
so i lest with the 661 and the 504.
i love the 47mm of the 504 but the carbotech looks amazing as well at the 661.i saw that the cp is sunken witch is turn off for me.
what should i buy??
nardin
1,850
81
what should i buy??
The 643 also amazing... Rrrr
Sent from my SM-G930F using Tapatalk
mysterio
9,793
867
Among the 4 you listed, the PAM661 (Luminor) and the PAM643 (Radiomir) would be the best options IMHO. Not sure about the sunken CP on th ePAM661 as I've seen two and both of them had flush CPs. The PAM643 does have an issue with its CP (it's oversized, looks to have a ring around it if I remember correctly) but there was a mod done by another member which needed a standard Radiomir hand set. There is an H3 CP installed already underneath and you just need to polish it. That is, if you're up to modding it.
nardin
1,850
81
Thanks for the reply.
I did a lot of research and settled on the 504 or the 532....now I have to choose
mysterio
9,793
867
Good on you. :) Love your avatar, I have one. :D
