Hi Guys,
I am slowly collecting the parts to franken my 42mm PO.
I have the gen hands, datewheel, crown, tube HE valve and a Sunnydale crystal.
It will also be getting a custom movement holder for a ETA 2892 (which is what the Omega Cal 2500 is based on with a co-axial movement). I can then fit a gen 2500 at some point if I got one.
Anyway - my question is this...
With a gen HE valve; why do people seal them with epoxy from the inside? The old HE valve is just pressed in and the gen is threaded so providing you can then thread the case with the correct thread size it should be water tight and be a functioning HE valve.
Yes I knowI wouldn't use that properly anyway as I won't be saturation diving, but the gen HE valve is waterproof to 5 ATM when the crown is undone let alone when it is screwed down.
Are people just going the extra mile to make sure it is watertight?
Seems a little over the top - unless it is likely to leak from the threads?
Any advice here would be great.
Thanks
CH
Thanks
CH
