Gentlemen,
this is a Picco Azzuro no CG sibling but with a crownguard and a display CB.
In spite of its 47mm size the watches is still quite comfortable for everyday use. The Aegean blue color is just perfect for the summer season.
It's not a rep since there's no gen PAM PICCO AZZURO model, it' s an absolutely custom and unique build.
It will be offered for sale in the Collectors Watch Corner section soon.
Briefly about:
- Cartel 47mm Crown guard case. Slightly reshaped midcase, softened edges, slimmed bezel. Engraved between lugs. Significantly improved water-resistance.
- Thick low double-dome crystal without fisheye effect. No AR.
- Heavily modded crownguard and lever. The lever operates smoothly. Custom made flush pin.
- Modded and engraved display CB.
- Custom made Aegean blue LPF dial. Sunburst effect. Glossy finish (the gloss lacquer layer has certain imperfections but overall look is pretty smooth and accurate).
- Custom made 0.3mm brass backplate. White lume with turquoise afterglow. Soldered dial feet for 6497 movement.
- Custom made carbon steel Long Wide Double Pencil hands. Soft brush finish. White lume with turquoise afterglow.
- H3 CP/HW.
- Completely serviced (washed, oiled, re-assembled, regulated) a6497 movement. Second wheel's pivot has been correctly cut off and polished. The wheels and ratchet screws are re-polished and heat blued. The Train bridge wheels are radial brushed.
- Titanium lug tubes.
- Custom Aegean blue 26mm leather strap with a buckle. 2 layers, quite comfortable. Size is 135mm x 85mm.
And a few pics:
Briefly about:
- H3 CP/HW.
And a few pics:
