Piaget Polo S G0A41002 differences between MFK and 3AF versions
iliov
11/1/19
Reactions: Kimdot16 and vcappp
Spooky27
The cheaper one has a more reliable movement, but doesn't look as authentic.
Reactions: vcappp
iliov
11/1/19
Spooky27 first of all thanks for your replay,
may ask you to be clearer about the look of the cheaper version?
Are you talking about deal thickness ?
thank you
Spooky27
thank you
I'm not very familiar with the gen Piaget watches, so hopefully someone else here can provide more insight. The normal Swiss, Japanese and even some of the Asian movements are extremely reliable. It's then that those reliable movements are modified, that they become less reliable. Think about installing aftermarket pieces on a good, stock car. While it can be done (if done correctly, with the right pieces, it's generally less reliable than stock). One of the best examples are with the subs. The stock a2824 movements are far more reliable than the SH3135, however, the SH3135 look much more realistic.
My opinion is, anyone who looks at your movement, and knows what they're doing will instantly be able to tell it's not gen. (unless heavily franked'd)
You need to decide what you are trying to accomplish with your gen. Are you trying to have a nice, reliable timepiece that resembles the style of the gen, or are you trying to trick people into thinking you're wearing an expensive watch.
iliov
11/1/19
Spooky27 You opened my mind to a new vision !
I agree with your first option, I’d like to get a nice rialable timepiece that looks and works like a gen.
So I guess you’re suggesting me implicitly to buy the most expensive version. right? ????
Thank you !!!
Spooky27
Thank you !!!
I think you should get advice from someone who is familiar with Piaget. The only way you are going to get a watch that functions and looks like a gen, is to buy a gen.
Look into the Sub forums, and you will quickly realize that the more reliable reps are not with movements that look gen (again, unless heavily modded or franken'd). You need to decide for yourself. In my experience, generally when you spend a couple hundred $'s more on a high quality rep, it looks more realistic, but in this case it comes with a less reliable movement.
Most people buy the less reliable movements in subs for the same price as the more reliable movements because they accept gen parts, which makes modding them easier and opens more possibilities.
ssouthall6
3,551
1,564
Don't they both have the same movement?!
I had the 3AF version for a while, it was a good watch for the money. Not seen the MKF version in the flesh though
Reactions: iliov
iliov
11/1/19
Spooky27 To be honest because I’m a biginner your advices are very important, as well as for the ones I hope to receive from Piaget “specialist” !
Probably because we are talking about reps anyway I will consider to start from the cheapest.
Thank U !!!
iliov
11/1/19
ssouthall6 They should be different movements, I’m waiting for clears opinions about them .
thank you
Horace Derwent
162
103
Being a Piaget fan myself i reup this thread .....currently i'm waiting to receive a 3AF Polo S with Grey dial from Andrew.
Studying the photos the MKF version has a slightly better decorated Miyota 9015...i'll test the waters with the 3AF model.
I'm pretty sure i'll buy the MKF version too,seems to be the only one with the fantastic green dial !
Secundz
DO NOT TRADE WITH ME
30/9/17
15
Would be interested to know your opinions once you guys are getting your pieces in the flesh. thanks!
Horace Derwent
162
103
What I can tell you is that the MKS ( it actually says MKS and not MKF) is fantastic!!!!!
The quality, the weight, the feeling is Gen like.
The deployant clasp is smoother than my Gen Tag Heuer Caliber 5, nuff said.
If you can, go for the MKS ( MKF???) version, moreover as a factory I saw that MKS is specialized in Piaget reps.
Reactions: vcappp
Horace Derwent
162
103
I would like to add that BOTH versions use the same Myiota 9015 movement, but of course the MKF version is much more detailed.
So, no reliability issues in both cases....
Reactions: vcappp
vcappp
1,000
296
Does MKS version have a loud rotor noise problem due to use 9015 movement?
Vineetd23
840
779
Los Angeles, CA
Has anyone seen a rep of the stainless steel black version on a rubber strap?
Sent from my iPhone using RWI
Kimdot16
29/12/22
France
I'm reading this very carefully, i plan to buy my first rep and i'd like to be a piaget polo. I went to the boutique to try the gen.
I'm still considering the factory though. Heard MKF is the best for piaget
Horace_Derwent
1,972
3,615
Cyberspace
Yes, definitely MKF.
Wonderful watch, i am maybe a little biased since Piaget is one of my favourite brands, but for me the Polo is the best looking integrated bracelet watch.
