- 9/7/12
- 25,042
- 23,636
- 113
Phong. Everybody knows the name . Purveyor of high end 'gen' spec' 'Rolex' parts. Gonna need a respectable paper stack though if you wanna buy off Phong - this shit's phucking expensive - $1400 for a case, $200 for hand sets etc.
The best thing about Phongs cases is the engravings- they're cleaner and crisper than Rolex engravings - which would mean they aren't really gen' spec' . . .
The worst thing about Phong is, well, Phong. His 'vintage' case refinishing is plain weird. A Phong vintage refinished case looks like a blob of ice cream that's just starting to melt in the sun. Everything is soft, rounded, indistinct.
Below is a Phong 'thin case' 1665 DRSD. Except it's not really a 'thin case', it's a thick case with the top shaved off on a lathe. That's cheating - and it's not gen' spec'.
The 'thin case' 1665's actually used a 5513 case with HEV as the base - this was later replaced with the dedicated 'thick case' to make the distinction between the SD's and Submariners.
This Phong 'thin case' case needed some work - an almost total absence of straight lines and flat surfaces, and a general level of finish that means you wonder why you paid $1400 for it, especially if you have to send it off to again to get it sorted.
At the workshop in Compton (DaPhuck Rephinishing, next to the McDonalds) they did a great job as usual.
Before:
After:
Thanks for looking.
Before:
After:
Thanks for looking.
