PF Nautilus Review.
Keylog74
3,860
1,696
This is a review ive found online and made me decide to go for this Nautilus.
ill include pictures and some of the selected text from the original thread. Please be aware that this is not a TD and some of the text does not make much sense but we are all for the picture after all! :)
Advertisement slogan of Patek Philippe that “no one can embrace Patek Philippe really. It just take care for next generation.” Charming appearance and elegant module make nautilus be popular globally. Today the most top version of Patek Philippe sports series of 5711/1A nautilus, which produced by PF from market to disassemble and evaluate for you, let’s see how 2000 detoxifies 180,000?
Let’s understand basic infornation of PF 1:1 best Patek Philippe nautilus 5711/1:
Color of index dial, polish watchcase and chain, re-upgrade module deck, it is the best PP in replica watch market, diameter is 40mm, thickness is 9mm, adopts Japanese 9015 module changes into cal.324 automatic machinery module <certified product is self-produced Cal.324S C module>, sapphire glass, 316 steel watchcase and watchband, luminous dial indicator, folding buckle and proof water for 30 meters.
Size of index dial is 40mm, its design aspiration of shape is originated from porthole which all of ships will have. Deep blue index dial makes people feels deep and quiet, which is confirm with classical temperament of Patek Philippe. And it equipped with calendar which has strong operating characteristic
Index dial is not only a single object, but a microcosmic world, the dial effect is decided by applied destined technique. Its unique not round or square metal hull and nautilus’s “unique reflect light” formulated by gathering of various metallic luster like wire drawing, mirror surface and matte, multi-layer shape, texture and lustre, the back elegant crafts is worth for appreciating:
Mirror surface adopts slug and knock resistant sapphire crystal, reflected color changes between gray and blue with light angle and environmental temperature. If it is normal wearing, it can keep no scratch for a long time and be scratch-resistant.
Hull adopts stainless-steel material, harness id high and not tend to be laid of deep scratch, its manual work is every in place. Stainless steel material matches with excellent structure makes this watch be more solid and durable.
Although index dial of nautilus series’ watch seems simple and unadorned, it needs professional knowledge and crafts and made by rich-experienced craftsman manually. This watch’s unique index dial ornamented blanking horizontal horizontal relief pattern. With 40 anniversary of nautilus series birth, nautilus made a limited watch, gold blue index dial inlays oblong cut diamond, diamond inlay can bee made only by manual.
Deep blue round index dial, present effect of gradual change of depth to lightness from inner to outer, manifest generous and sedate temperament
Taking watch mirror down can see its literal clearly, dark blue is very fluttering, literal grinding crafts is elegant, which can be called a large factory’s crafts, PF factory’s design of nautilus is top crafts in color control, it seckills every other versions.
This watch selects the most classical three-hands time display, three-hands shares one index dial, the hand in silvery, time scale is gold stereo timer and distribute in blue index dial. It not only can make index dial seems brief and classical, but has high readability, this stereoscopic feeling makes the whole watch looks more sporting.
This watch has a highly-practical date display function, it can be seen from following picture that data display window is located in direction of three o’clock, white background matches stick markers, which is not onlt generous and beautiful but has strong readability.
Screw-down crown, strengthen watch’s waterproof performance, with water-proof rubber ring of front cover, because this watch’s waterproof performance can be more outstanding. It can be worn in summer when swim in pool.
PF nautilus adopts Japanese 9015 modules Custom modified into cal.324 automatic machinery movement, certified product is self-produced Cal.324 SC module, this is back through design, as to appearance, module’s back remastering is consistent with certified products basically. Module gemstone can be seen clearly through the back of deck and plays the role of ornamenting for watch. Deck is polished elegantly, manual work is good, which embodies diligence degree of replica factory. Additionally, what need to emphasize is this module can provide motivation storage for 45 hours, which is suit with nowadays modern people’s rapid life tempo, you don’t need to worry watch run-down to re-timing though you don’t wear watch.
Inner and outer deck is very elegant in grinding, surface mark and stamp is clear, which exhibit factory’s diligence.
Great swing, co-chain efficiency is high. And the most attractive and beautiful design is Patek Philippe
It can be determine the position in Patek Philippe’s top, and it will become a bellwether in Patek Philippe’s top field. And it can remaster just if it adopts this Patek Philippe watch of module back, even the similar type. Therefore, this watch’s promotion has milestone meaning
Designing of protegulum is same with certified product, it can dismantle freely and it equipped with water-proof rubber ring, remaster is able to grasp detail and consistent with certified product completely.
Watchband adopts 316L stainless steel material, silvery watchband can embody wearer’s temperament, fold clasp can be easy to wear. the middle parts on the bracelet is Arc convex which is excactly same with original watch. the bracelet connect part is very well polished much better than another factory 5711.
the watch buckle has nice shap. the buckle shap just same with original watch buckle. i did personally comparison with original watch buckle.
the buckle connection part are well polished and made. the screws size and shap just same as original watch screw. this is super 1:1 copy from PF .
the watch bracelet serise number as same as gen watch
the watch casing thickness just as same as original patek 5711 thickness. very well made
the lume is very very nice. super lume made in swiss. and the color and light just same as original patek 5711.
the front casing has waterproof rubber ring. which can easyly and perfect protect your watch. as same as original made.
The font, size, size and thickness of the calendar are exactly the same as genuine
the PF custom made very well movement. you can see that gear just at same position as gen watch. the most important is the movement thickness is ecactly same with original watch thickness. when you wear it. you can really feeling you wear a gen watch. it's really cool. the rotor PP logo carving and word engraving on the movement. very detail and good quality.
the PF casing mould made very well.
the pack box of PF patek 5711 is SUPERB ! 1:1 from original box set. no difference at all. i really can't see there is any difference with gen watch box. PF They made great efforts?
The latest creation?PF factory made ceramic part screw cover where can protect the screw where connect buckle with bracelet. this is Bold attempts and latest experiments. Praise for this innovative spirit!
the Incomparable beauty watch dial is perfect. everywhere made really detail and close to original.
Ensemble
Stainless steel material, with factory’s who improvement to manual work of steel band, embodied full of texture, deep and quiet deep blue makes people feel a distance beauty which can be seen from a far place only, it is a luxury pursue it can be played in hand.
conclusion: the design of this watch has some features, although its positioning is sporting watch, its sporting feeling is not from complex sporting function, the more is embody sporting temperament through exterior design, classical three-hands display and coated luminous coating, yo can see the watch even in dark. Without complex design and complex function, display is classical and brief. Although it is a sporting watch, but it can do a job with skill and ease if as watch of official wearing matching with suit and it can mach with any dress. This watch’s meaning and manual work is the king of steel watch. With technical upgrading of PF factory, it remastered this limited watch elegantly and perfectly, then make more people to embrace and collect it. Finally, it is a good choice whatever appearance, texture, operating characteristic or collection.
My personal advice would be this: Go for the blue dial if you want to keep the watch stock...
majwilliams0308
Reptime Mod
2,443
2,407
Excellent review. Lots of TSWatch photos - but they always take great pics. Was this copy/pasted from their site? Just a warning they aren't a TD here any longer.
Keylog74
3,860
1,696
Yes.
I said that at the beginin, they are not a TD but this is a review not a FS so i think there is no problem on posting it.
majwilliams0308
Reptime Mod
2,443
2,407
Yes.
Yeah definitely. I am quite tempted to sell my MK v4 for this. Thanks for putting this here!
glee79
447
64
If PF takes it time to make a V2, they are gonna sell ALOT.
I would say they need to fix: DW font thickness, White ones Lume and the general Dail markers misstakes (just use 10 more minuts when mounting it).
nicks
283
Are they makin a new version of this now? any release date?
