Pelagos ZF vs. V6F pros and cons
simonm
137
13
I've been wondering which of these to models of the Pelagos rep is best? i know that both of them have some flaws etc. but i wanted if someone whit a bit more experince and expertise could point out the pros and cons wih each of the above mentioned models
thanks in advance
Radman
1,908
Multiple, and detailed, threads on this.
Spoiler alert...there is no consensus on this.
lolersd
MULTI ACCOUNT
25/8/14
146
I heard that the V6F is better, but you should do the research yourself and decide which one you prefer.
PerryJ
117
I personally have the V6f. The bevel has a little bit of play, not much at all, maybe 1/4mm. The bezel loom is also total shit. Other than those two gripes the watch is excellent. I had it WR and it held 500m WR so I'd say its a solid build :)
C124
703
114
England
I got the ZF as it came with a rubber strap included. First impressions are very good, my only gripe was the helium valve cap on the side of the case fell out pretty much the day after I got it. I managed to get it back in but I won't be going anywhere near the water with it, that's for sure
simonm
137
13
Okay thanks for all the answers so far :)
and yeah i know i should try to look it up my self, i have tried but as you allso mentioned i did not really get any conclusion
WatchPorn
264
36
I hear these pop out... is it screwed back in? how does it stay in...did you glue it?
C124
703
114
England
Yeah, it screws back in but You have to compress it down whilst turning it to get the thread started. I used a rubber marigold glove to grip it and get some turns on it. Also applied some light strength loctite.
Arko
94
I greased the HEV and then loctite and screwed it in from the inside with a flat head
zsolie
145
How did you grease the HE valve? I heard it's one piece and unscrews from the inside. Is there any gasket inside?
WatchPorn
264
36
when I get mine, should I just try and unscrew it (if that's doable) and throw some loctite on it before it even gets the chance of falling out?? that would be pretty embarrassing!
Arko
94
I have a ZF and there was 2 gaskets in the HEV, one under the outter valve, one around the end of the screw threads of the assembly. I put grease on a piece of plastic and slid it under the gasket of the valve
C124
703
114
England
I wouldn't pull it out if I were you as you would likely compromise any water resistance it may have. I'd just check its tight. It was really fiddly to tighten due to the gasket on it , I'm not too up on taking my watches apart so I couldn't do it from the inside
Arko
94
I unscrewed the HEV, greased it, then loctite'ed it back into the case. should be better sealed than stock
zsolie
145
In this way the HE valve function will remain? Or you loctited the whole assembly and fill from inside the hole with glue?
Arko
94
i leave the valve functional, loctite was applied only to the threads holding the assembly to the case
zsolie
145
Ok, now it's clear. And do you trust in the HE valve small "O" gasket? This isn't the weakest point of the watch WR?
