{*PCTeam*}SIHH2017 -Luminor Submersible 1950 BMG-Tech (tm) 3 Days Automatic – PAM00692
mysterio
9,794
864
A NEW WORLD PREVIEW FROM THE PANERAI LABORATORIO DI IDEE: THE FIRST WATCH CASE MADE ENTIRELY OF BMG-TECH (trademark), A METALLIC GLASS WITH EXCELLENT CHARACTERISTICS OF STRENGTH AND DURABILITY WHICH ENABLE IT TO PRESERVE ITS APPEARANCE OVER TIME.
The Panerai Laboratorio di Idee presents an invisible but revolutionary innovation, resulting from its continuous research into design and new materials: BMG-TECH. The secret of this material, which has been used to make the case of the new Luminor Submersible 1950 BMG-TECH 3 Days Automatic, lies not so much in its appearance – which is similar to that of titanium but darker grey in colour – as in its atomic structure, which provides a range of very useful qualities for an underwater watch: extreme resistance to wear, high strength and great lightness.
BMG-TECH – the material of which the case, bezel, winding crown and associated protection device are made – is a metallic glass (Bulk Metallic Glass), that is a material made from a special glass-like alloy in a way which prevents crystallisation, so that the atoms do not arrange themselves in regular geometric structures. The alloy (consisting of zirconium, copper, aluminium, titanium and nickel) is subjected to a high-pressure injection process at a high temperature and then to a cooling process lasting for only a few seconds, so that the atoms do not have enough time to become arranged in an ordered, regular structure, as normally happens in crystals. The “chaotic” structure of the material is the secret of its properties – in particular, its extreme corrosion resistance, its great robustness and resistance to external shocks and its resistance to magnetic fields – bringing further advantages to the owner of a watch which also provides excellent performance while preserving its appearance virtually unchanged over time.
The innovative properties of BMG-TECH provide additional features for a model rich in technical content and of unmistakable Panerai identity. An underwater instrument with water-resistance guaranteed to 30 bar (a depth of about 300 metres), the new watch has the bezel with a graduated scale for calculating the time of immersion, which rotates only anti-clockwise, the date window at 3 o’clock and the seconds counter at 9 o’clock. The clear markers on the blue dial – which has a new polished finish creating fascinating reflections – provide absolute ease of reading and excellent visibility under all lighting conditions and even in the dark, thanks to the use of two different types of Super-LumiNova® on the markers, making it easy to identify the reference points for reading the time and the length of immersion.
Entirely developed and created by the Panerai Haute Horlogerie Manufacture, the movement is the P.9010 automatic calibre with a power reserve of three days. Consisting of 200 components and with 31 jewels, the calibre is 133?4 lignes in diameter and 6 mm thick, which enables the thickness of the case to be reduced. The balance is fixed by a bridge with twin supports and it oscillates at a frequency of 28,800 vibrations per hour (4 Hz). It is connected to a device which stops it as soon as the winding crown is pulled out, so that the watch can be synchronised with a reference time signal. In addition, the hour can easily be adjusted without interfering with the movement of the minute hand, by means of the device which moves the hour hand on its own, in jumps of one hour forward or backward. This function is very useful when changing time zones or moving between summer time and winter time, particularly since adjusting the time automatically changes the date when necessary.
The back of the new Luminor Submersible 1950 BMG- TECH 3 Days Automatic (PAM00692) is made of titanium and the strap is made of black rubber.
- MOVEMENT Automatic mechanical, P.9010 calibre, executed entirely by Panerai.
- FUNCTIONS Hours, minutes, small seconds, date, calculation of immersion time.
- CASE 47 mm, BMG-TECHTM. DIAL Blue with applied luminous hour markers. Date at 3 o’clock, seconds at 9 o’clock.
- POWER RESERVE 72H.
- WATER-RESISTANCE 30 bar (~ 300 metres)
Hmm, a watch made out of glass that does not look like glass. Interesting... Although it would be exciting to have the factories replicate BMG, a titanium case would probably suffice.
ernien
785
163
Ontario, Canada
Well considering the factories have repped Cermet in AP's, this might not be too much of a stretch for them. Exciting stuff!
mysterio
9,794
864
Not sure how close or far Cermet is from BMG but it's a starting point.
OliverQueen1985
17
Does anyone know if there's a rep currently in production or being made?
Sent from my iPhone using RWI
