- 18/1/11
- 19,846
- 423
- 83
PROVISIONAL IMPRESSIONS - Prototype of PAM 113 Noob dial
As you surely know Toro is developing with Noob new versions of Pam 113 and 114.
Some months ago Toro presented prototypes of the new dial PAM 113. After some corrections, more samples and many discussion about this matter. Toro decided to send me a dial sample for review in order to get information for the maker about flaws and necessary corrections.
As you know I don’t like PAM white dials and have not enough experience about these dials. I didn’t like to do the review because I have no gen to make comparisons, but Toro insisted and sent me the dial
Today I have already seen the prototype of PAM 113 dial from Noob kindly sent to me by Toro
I have examined this dial, take several pics and made some Photoshop overlapping comparisons in order to get some provisional opinions about this dial.
I have also examined several pics of H maker Pam 113 dial to make some comparisons and determine the possible improvements of new Noob dial.
As above said this is a first contact and the conclusions are provisional, to be confirmed and proved by more pics, comparisons and analysis.
All opinions below written are obtained after some hours analyzing carefully this Noob PAM 113 dial
In some days I will publish the final conclusions and the pics supporting them. When I get confirmed pics of gen modern series. This is other added problem, because Panerai has introduced some important changes in last series.
It is very difficult to take final conclusions, valid for the maker, without a side by side comparison. But I cannot get a gen at this moment.
It would be interesting sending a Noob dial to Goin from Taiwan, who owns a gen PAM 114. Since it is a PAM 114, we will not be able to get the subdial comparison but we will get a comparison of the overall appearance of the Noob dial. Goin takes very good pics and is an expert. I could ask him for this job, he is a nice and good friend.
Below my first and provisional impressions about the prototype of PAM 113 dial from Noob. Pending to be confirmed by comparison with confirmed pics of gen modern series.
1- FINISH AND APPEARANCE
Finish and appearance of Noob dial are very good with a nice broken white colour shiny but no in an aggressive way, leaving the prominence of shine to the nice markers which are nicely raised and very glossy.
I have not seen the H maker in person to judge
I haven’t been able to make direct side by side comparison to gen in order to get an opinion about accuracy of colour and finish.
2-SUBDIAL @9
Noob subdial is not at all recessed, it is clearly raised like H maker. I will show pics to prove it clearly. No doubts about that. Even sliding a nail over the dial surface you come up against the edge of the subdial.
Gen has about 28-29 concentric circles, Noob and H maker have about 21 circles
Therefore the pattern of circles is clearly finer in gen
Subdial stick markers are accurate in shape and thickness, but the rep black paint copies the circles pattern more than gen paint. Somehow gen paint cover better the groves of circles. That is helped for the finer groves in gen.
3-MARKERS
Little stick minute markers around the dial in reps are longer than gen and seem thinner.
Numeral markers have overall good thickness in both reps, with sharpness and definition. Markers are nicely raised with “body†and volume and nicely glossy like gen.
Some markers are better in Noob and others seems better in H maker
“12†marker is displaced laterally in both reps. To be confirmed, but it seems displaced in both reps.
“6†is seemingly wrong in the same way in both reps.
4- DOTS WITH LUME
This is a matter to be confirmed with correct gen pics because I have found many variations
Dot’s black contours have the same external size in gen and both reps, but the lume in reps has a bit bigger diameter and leaves less black contour to be seen.
But the most important is that rep lume is much flatter, whereas gen is almost a half sphere.
This is a flaw of both reps to be fixed and very noticeable
5- LUMINOR MARINA & PANERAI INSCRIPTIONS ON DIAL
Inscriptions are raised sharp and glossy like gen in both replicas
Fonts are a bit higher than gen and have some differences.
Curiously both reps have the same flaws and the inscriptions seem the same
Even PANERAI is placed a bit lower in both reps
6- L SWISS MADE L
It is very similar in both reps and has the same flaws.
Fonts are higher in both reps
Both reps have “A†with the upper vertex square shaped instead of almost angle shaped like in gen.
This inscription is also very similar in both replicas
7- GENERAL LAYOUT
General Layout is quite good with some clear displacements of markers but not very serious. Maybe 12 displacement is more serious (to be confirmed)
There are some flaws already confirmed and other to be studied and confirmed. But it is clear that subdial is not recessed, lume dots are flatter than gen which are almost a half sphere, L SWISS MADE L has differences and contour little stick markers are longer in reps.
I honestly think that Noob dial is made with the same base as H maker dial with some improvements and some worsenings. The subdial is almost the same, if not the same.
Threfore, no found improvements at this moment in Noob dial over the current H maker
As above said I will try to publish asap a full review, if I find correct gen pics of modern dial, showing all flaws through pics, in order to send this info to the maker.
Please wait
ALE
2-SUBDIAL @9
3-MARKERS
4- DOTS WITH LUME
6- L SWISS MADE L
7- GENERAL LAYOUT
Please wait
ALE
