Patek 324SC stem release and removal
jkrw247
1,200
484
Hi experts, can I confirm that to remove the stem for this movement, I need to put the crown in time-setting mode and press the circled area?
Thanks!
tongsui
1,608
1,153
Assuming you referring to 3kf 324sc ? If yes then yes , go gentle with 3kf 324 stems , they known to be quite fragile
jkrw247
1,200
484
Yes, 3KF 324SC
Point taken. I'm aware of this from the 3KF threads in the Patek section. Thank you for the reminder.
May I please double-confirm with you:
1. Pull out crown to time-setting mode
2. Press the area circled in black
3. Remove stem
Actually, does the stem position matter for this movement?
tongsui
1,608
1,153
Yes, 3KF 324SC
3. Remove stem
Your steps is correct , just to clarify
Gentle Press the stem removal button(hold it ) , then gentle pull the crown .
When re inserting , reverse the process , you may need to give a slight turn if it doesn't slide into position .
The keyless construction doesnt look like it matters but having it on time setting minimise chances of the yolk to slip of of position.
Reactions: jkrw247
zinduna
1,116
643
Very helpful, thanks! Glad I came across this post.
Reactions: jkrw247
