Panerai setting
parisman123
59
Guys, I'm new here and after being a skeptic of Panerai my first Panerai came through the mail. Sorry for being so new, but how do you set the time on this thing? And also I rotated the crown too much now it stopped rotating is that normal?
JOEJOEJOE
1,072
so... rotating the crown winds the watch... If you want to set time, you unlock the crown guard lever, and pull out the crown a little bit and then rotate - you'll see minute & hour hands moving... after you're done, push the crown back in and lock the lever on the Crown Guard.
Joe
parisman123
59
thanks
which way am I supposed to turn the crown to wind it? because I turned it upward about 20 winds now it is stuck, is this normal?
tootall
Vendor (Strap Maker)
2/5/06
1,343
Re: thanks
Did you take the crown arm away from the case yet? If you are turning it while the crown arm is down that may be the problem.
JOEJOEJOE
1,072
Re: thanks
Yeah, it means it's fully wound. It's normal (the watch is running, right?). Upward is correct. from 6 to 12.
Joe
crumpdaddy
1,716
If it's a manual, it's supposed to stop winding at some point.
Which Pam model did you purchase?
parisman123
59
yes i was rotating it while taking the crown protector out, but i didn't pull the crown out to fix time, i just opened the protector and turned up upward. but now it doesn't turn anymore
crumpdaddy
1,716
I have the same watch. You have reach the max wind point.
Wind again in 40 hours.
*peace*
