Just arrived from the Pacific Northwest, I think this piece is just gorgeous. So happy I was able to snag it!
Model:
Stainless Steel Case, Black Dial, Black Subdials
Movement:
Hand Wind Lemania Chronograph
Functions:
Hours, Minutes, Seconds, Chronograph
Dimensions:
42mm x 11mm
About this watch:
Panerai Radiomir Chrono wristwatch, limited WEMPE edition of 125 pieces only, reference #PAM 00204. Hand wound mechanical movement OP XVI base Lemania. Polished steel case, diameter 42mm water resistant to 100 meters, polished steel bezel. Black dial with luminous hour markers and numeral 12 & 6 with tachymeter scale outer flange. Functions: hours, minutes, small seconds, chronograph. Screw down winding crown. Sapphire crystal see through case back.
On 10th October 2005, Wempe Chronometerwerke celebrated its centenary. The outstanding feature of this anniversary wrist watch, which was created especially for Wempe’s 100th anniversary, is the Caliber 1872, which was built by Nouvelle Lemania, the renowned manufacturer of blank movements for most of high grade watch brands such as Patek Philippe, IWC, etc. Extraordinary accuracy is one this caliber’s most appealing attributes. Eighteen jewels, classic gear coupling, and a balance that vibrates 21,600 times every hour combine to guarantee precise timekeeping. The balance’s frequency enables the watch’s user to stop intervals to the nearest sixth of a second.
Model:
Movement:
Functions:
Dimensions:
42mm x 11mm
About this watch:
