The reps you are talking about are low grade reps not only for the movement, the rep case is completely different since is a standard Luminor 1950. whereas the gen has a very special case similar to the case of PAM 372 but adapted to chrono
Quartz is not compatible with PAM spirit, if you like Quartz you should change of brand
Try an automatic movement you have very good PAM choices with these movements
ALE
