Panerai PUNCH HOLE ...
moggio
2,788
Hi everyone...
I like to ask where to get a punch hole for straps ..I need it to adjust my strap ...coz....some of the strap is to big for me..so need to make a few holes...and its very hard to get the almost oVAL holes on panerai..its unusuall..
Please help with some info...Im wearing my pam like some idiot ...keep hanging on my wrist loose...
cheers
takashi
11,500
You can take the strap tp a reputable jeweller to make a good hole. However, if it's too troublesome for your find a jeweller, you can order a shorter strap next time. For example, you can order from TCStrap a 115/75mm strap instead of 125/80mm. I have a small wrist too, the 115/75 will fit nicely.
rbj69
2,358
26
u will never make the hole as perfect as factory cause it is fresh glued when they punch it and it makes it mold better , hence the nice beveled inward edges but u can achieve a decent hole from a shoe repair leather shop and or i have seen the oval punches on ebay every now and then
moggio
2,788
nice...
thanks for the response..I will try to order new strap soon..after some saving ...and for the ebay stuff..will try to look at it ..thanks guys ..
DRVJA
50
PUNCH HOLE
GO TO AN EQUESTRIAN TACK SHOP THEY HAVE HOLE PUNCHES TO USE OR TO BUY I HANE ONE IT COST ABOUT 30
Repmaniac
1,439
Ok.....here's a real cheezy way of doing it, but it does work (the proper punch, of course, is the proper way).
Go to your local hobby/hardware store, and buy a couple sticks of SS or brass tubing.......the hobby kind, not the fix-the-toilet kind. They're about a foot long each. Get the diameter that is just slightly larger than the diameter of the hole. Cut it into 2-3" sections, then, if it's an oblong hole (oval), take a pair of pliers and squish JUST THE END to the proper oblongedness (?)
Place the strap on a hard surface, put one end (or the squished end if that's the hole you want) of the tubing on the strap, and whack it with a small hammer. You MUST KEEP THE TUBING PERPENDICULAR to the surface! It'll take two or three whacks, but it WILL punch a perfect hole through leather. It's the whole physics tubing compression thing, kinda like a straw. You can bend a plain plastic straw with your little finger, but if compressed while perpendicular (straight up-and-down), it will support 20-30 pounds or more.
It also helps if you slightly file the punching end to a 45 degree angle........just taper the VERY end. It'll dull real quick, so you will only get about one hole per section. I used to own a race car fab shop, and used SPENT brass pistol cartridges to punch holes in gasket material for custom gaskets......makes a damn fine hole. .38 caliber for 3/8 bolts, .380 caliber for 1/4" holes, etc.
It'll cost 'ya all of 2 bucks and about 15 minutes to do. The secret is THIN-wall hobby-type tubing, not PIPE :shock:
moggio
2,788
cool
Really nice idea..will try to find one ...thats sound easy ...thankss man
