Panerai Pam 243 L Submersible a7750-H maker 386usd ===== price at 256usd now ===
H-Maker.Pam 243 L Series 1000m!!! This is the BEST Pam Rep Made to Date!!! Made with a Genuine 243 Completely Dissected ... 1 : 1 All Parts Except Movement and Needles Completely Interchangeable with the Genuine... Superlume C3 Dial and Needles... Exact Date Font and Mag!!! Colourless AR Coating ...
MOVEMENT: Asian 7750 Automatic Movement, 28800bph, Functional Regulator
CASE DIAMETER: 44mm (1 : 1 against the Genuine)
THICKNESS: 17.5mm
DIAL COLOR: Black Dial, Black Subdials
**Original C3 Superlume Applied on Markers and Needles
CASE MATERIAL: Solid Stainless Steel 316F Brushed Caseset
BRACELET: Hand-Sewn 24/22 High Quality Calf Leather Strap with Insignia Tang Buckle, Press Release Mechanism on Lugs (Exact Engineering Process as per Genuine... Very Smooth)
FRONT GLASS: Sapphire Crystal (Correct Double Radius As per the Genuins) Swiss Genuine Standards Colourless AR Coated on Crystal and MAg Cyclob (7mm) as per the Genuine.
BACK : Solid Case Back with Detailed Engraving
**Individual L Series Serial LXXX/500 nos and Matching Individual BB nos , Every Serial Number is Individual Engraved with Individual Scan Film, Not by Running Computer Program
CLASP TYPE: Tang Buckle
BEZEL: Uni-Directional Rotating Bezel (60 Clicks) Diver Bezel with Fine Engineering Finish and Knurled Grip on Sides
THICKNESS: 17.5mm
