Panerai PAM 000 P series little project
Debellum
Love is a Litany
4,876
289
Hi Mates
I own a Panerai PAM 005 by Noob which has a no superlumed dial... It's a P serial.
I had this sausage dial made , from Panerai PAM 000.
I disassemble the dial + hands set and I cut the seconds pinion for fit this , transforming it into a PAM 000. The case and CG should be perfect , then they are by Noob.
What do you think ? I made this PAM 000 dial cause it's impossible to find a Noob or XF dial for the 005.
If someone has a dial instead (Noob or XF) for my 005 can contact me. ;)
Thanks for your attention.
Junio M.
Debellum
Love is a Litany
4,876
289
I’ve token a decision.
I build a PAM 000 with this dial.
Serial Number it’s ok , Case & CG here’s ok.
So , when will I’ve finished the works I will open a thread about.
Regard
glay78
353
I built a 000 with noob case, Gen dial and hands with Gen crown guard and a custom caseback with Gen serial. Awesome built but no wrist time unfortunately.
papabear244
527
157
It should work. Some people don’t like cutting the seconds hand pinion. I do it and as long as you sand and polish it properly, it should not have any problems. As not to leave any jagged edges. Also oil it a little.
