Panerai experts I Need Help
Robb
787
Does anyone know what size straps will only fit the 45mm Radiomir ?
I have 24mm straps, just not sure how they will fit a 45mm
Sent from the RWI App
goin6633
1,297
45mm or 47mm radiomir are all fit 26mm straps.
???? Tapatalk ? SM-C900Y ??
Robb
787
Ok! So my 24mm straps wont fit the 45mm Radiomir models
They just dont seem to make enough 44mm models.
Thanks for your help
mysterio
9,794
864
If you mean 44mm Radiomirs, Panerai has never released a 44mm one. Only 42, 45 and 47mm are produced. Now if you mean Panerai as a whole, then you are wrong again. There are more 44mm PAMs than any other sizes.
Robb
787
all my straps are 24mm for both the 411 & 111 Luminors
Was just curious if the straps would fit the 45mm Radiomirs models
But they dont from the feedback.
Thanks
Robb
787
I really like the case shape of the Radiomir
Dont know if theres a 44mm Lumionor model with the similar case shape as the Radiomir ?
Lagunax
2,746
1,519
Thanks
No it will fit but it will look too small and weird. I tried. You need 26mm for a 45mm Radiomir and 24mm for a 42mm Radiomir with the wire lugs.
Robb
787
Yeah I thought so !
Would you know if there is any 44mm Luminor models with similar side case design as the Radiomir.
Robb
787
Yeah your correct !
Anyone know if theres a polished case version same as the 310K Pam case in SS ?
I seem to find it only brushed ?
Wanting to buy it
Robb
787
Need to correct myself
Its the 312P shape case im reffering too.
Does anyone know if it comes in a all polished case ?
Can only find this shape in a Brushed ?
Thanks
