Panerai Bianco Sub PAM 1223
BlueLineFarmer
1,482
812
superspark69
3,180
2,249
Sheffield, UK
Loads,
XF and VSF 42mm Pams
a quick search on a td site or this forum will tell you, nearly all 42mm Pam subs have been repped. Apart from those released this year. This includes, both steel and carbon versions.
BlueLineFarmer
1,482
812
Loads,
Thanks as I should have searched.
Let's hope the Panerai Bianco Sub PAM 1223 gets repped in 2022 as I would be in for one as I have the perfect 22 mm strap for it.
superspark69
3,180
2,249
Sheffield, UK
Doubtful unless vsf start up again, which is doubtful..........
we can hope though.
JayBee0815
Repoholics Anonymous
9,824
31,633
Heart of Europe
Very nice, how does the smaller 42 mm case compare to a 44 mm or 47 mm case, does it look a lot smaller.
Yes, of course. But only if it looks smaller it does not also look more "filigree" because some of these models are rather thick in relation to the size.
Some time ago I had the 42mm Sub 683. With more than 16mm thickness this was a very chunky watch ...
Even more chunky is the 243 which is only 44mm in diameter but 19mm thick ..
In comparison to these two "small" Submersibles the 47mm 692 look quite "harmonic" ...
Although it is also more than 16mm thick. But here the thickness looks different because it distributes over a much larger body.
BlueLineFarmer
1,482
812
I'll let you be the judge; here are three different sizes of the 1950 case, starting from the bottom, the 42mm 1223, a 44mm 233, a 44mm 243, and a 47mm 389.
Thanks, the 42 mm looks small compared to the 44 mm and 47 mm.
