I was winding my watch today and noticed that the crown is a bit loose. I am not sure if this is normal or not as this is my first rep if this kind. I did a search and didn't see anything. I might just be a little paranoid but wanted to make sure the watch isn't messed up or will more than likely break. Is there anything i can do to fix this or is it not a problem at all?
basically when i am winding the watch the crown has a little bit of movement back and forth and side to side.
thank you for all the help guys.
