Panerai 232 Review (DSN Franken)
unregistered
416
11
Panerai Radiomir "1938" 232
Credit goes to taiji for first bringing this model to my notice and the steps on what to do to make it an "Ultimate". For a more indepth step by step as to how to make the franken, please read his review here.
This watch is frankened from a Josh/Andrew 232 case, movement, a DSN dial + hands. I was lucky, my movement already came with a high canon pin so now I have a spare set.
So on to the review of this frankened 232 vs. a Gen.
Front
1. Hour hand tip is noticeably shorter. Just the tip, the angle is off for the triangle. Take note, these are DSN hands which are more accurate.
2. The "A" in pAnerAi is still incorrect in the DSN dial, the bar is too low.
3. Most obvious tell on the dial, the "L Swiss Made L" is shifted to the left a little too much. Mine is approx correct in terms of closeness to the dial.
4. The crown tube is 1mm too long. The Gen is shorter. The crown itself is almost correct in terms of angles and sharpness.
The font for the numerals looks almost spot on, there are some very very minor differences, but so minor the only way to see them is to overlay the images.
The color and size of the font you can see is just a smidgen off. The Gen appears to be in a slight ivory shade. Other than that, though the dial colors look different, I can verify as can taiji that the DSN dial is bang on. In the shadows, the chocolate dial looks black as above.
Back
1. No engraved serial number
2. OP number is incorrect. The 232 has an OP number of 6659. The rep states 6609
Side
1. This to me has always been the biggest tells on the Radiomir series of reps. The case. The rep from Josh/Andrew has a "squarer" case more true to the gen, still not exactly there, but closer than the standard 183/210 reps. And the second thing to note is from the side profile, the reps always taper off to a squared/rounded point, whereas the Gen tapers to a sharp point as evidenced above. Biggest most obvious tell.
**Edit: Added flaw by ohmycocker
There is one additional difference. The lugs on the rep on radiomir is always too long and the angle of the lugs is slightly different (appearing a bit too straight), leaving a bigger gap between the strap and the case and has not changed ever since when there is rep on radiomir.
**: Added flaw by milesd
Also don't forget the polished lug wires on the gen vs. the semi brushed blah of the rep.
Capecod to the rescue!
Now on to some fun pictures;
Wrist shot;
Family Shot
Ultimate 232, Angus Ultimate 111E (Vaclumed), Gen RXW MM20
Lume over 2mins. 1sec exposure each shot
Overall,
this is a beautiful watch. The chocolate dial is stunning in person, a great departure from the standard black. I'm now awaiting this lovely strap from StrapCulture which will become the defacto strap on this Radiomir. SC Double Hatchet Light Brown;
It finally has some less obvious tells as compared to the standard Radiomir reps and I would be confident to wear this out. All up, a cheap rep as well, getting the watch head from Josh/Andrew and the dial+hands from DSN all up sets you back around $320 shipped.
Hope you all enjoy this.
daytona4me
Chinese Shrimp Rider
Administrator
14,206
12,738
Great Review!
Between your crystal clear points and your fantastic pictures, the review helps anyone who is thinking about purchasing this watch and making it better.
Fantastic Job! Beautiful Results! :D
I wish I could read your other reviews in your link but they are linked to repgeek where I am banned before being able to sign up. :(
unregistered
416
11
Sorry to hear that d4me, I'll repost them here. Its hard being on so many forums, you tend to kind of just stick to one though you'd love to help all.
Small stuff I can do to help, though I'm sure others have reviewed these pieces as well.
daytona4me
Administrator
14,206
12,738
That Lume comparison is priceless.. love the picture.. forgot to mention that. :)
Really makes this review stand out.. have not seen someone use a .gif in a review like you did. :mrgreen:
If it's an easy copy and paste,, we'd love to have them here,, if not... I understand.. and indeed,, just keeping up with RWI and RWG is difficult enough.. :roll:
unregistered
416
11
Yeah the lume gif was a huge hit the last time I used it to display my modded vintaged marina militare
As requested, posted some of my reviews here.
hooligan
8,332
Great review and pics!
Thanks very much for posting those. Love the gen MM20, BTW...
Pix
8,603
1,823
FR
Thx for sharing, that is a really well documented comparison :D
The brown dials on PAMs are growing on me, and that colour + Ti case might be my next choice.
unregistered
416
11
Same here, I'm eyeing a DSN 240 next. Once I can secure a Ti bracelet to turn it into a 279, I'm ordering the 240
cc
434
California
Great review of the 232. Your 232 is an fine example of a franken rep 8)
Also, I would like to edit my quote in your review. Regarding the Panerai engraved lugs, I was referring to the a gen 249 case as it is engraved "Panerai" on bottom side and "Opus Facere" on the top side.
I forgot where I had mentioned it...I must have brain farted.....
optimis9
266
Thanks for the great reviews, especially the lume shot. Really gives a good idea of the different kind/ price of lume.
Be even more interesting if you could tell us how long each one actually last? :D
unregistered
416
11
haha, no worries, I'll remove it then. I saw it in a thread over at RepGeek.
optimis9: The longest is the gen MM20 :) Understandably so.
Next up is a bit of a tie between the painted Vaclume and sammie DSN dial.
JSL
46
I always like these kinds of post. Very detailed comparison. It sure does help a newb like myself.
