Panerai 183 " La Review"....................
FMALDONADOG
82
Acknowledgement:
At forero Lockum, great person, pleasant to and illustrated in this world, which has helped shape my modest collection, and now ... two of his commanding the flagship of this.
Background:
When I started with you, the Panerai watches seemed more ugly in the world, is in question, even more. I resisted, but ... encouraged by the panerísticas fevers that flow strongly through the forum and infected by the hidden virus that I carry, I knew that sooner or later enter into the "black water" in the hands of divers from the primordial Italian Navy, with the help of a transmitter 183.
When we start trying to immediately increase the number of replicas of our collection. Thus acquire some of average quality, in the end we do not like or that are far enough from the original. This kind of replicas leveled down the value of our collection. It is preferable to have 5 replicas of "pata negra" before 10medianas (heh, heh I know that now.)
It says the value of the collection is greater than the sum of its parts. This has to do with the criterion, the changes that we make and the information we collect about the originals and replicas. Each replica we enter the library should know the history behind it.
But .... They are all so beautiful these timepieces ...
Try to tell you how this is Pam. 183 and inocularos to remove your virus defenses.
Replika Panerai 183 H
- Box of 45 mm x 13mm high
- Full Lume By Ziggy. relumeado dial and hands by Ziggy, modder recognized internationally.
- Canon Pin corrected.
- Manual Movement Swiss Unitas 6497 to 21,600 bph
- Sapphire crystal with an Ar-layer light-(not purple or blue dye)
- Original pam183 Correa.
I think it is difficult to distinguish from the original ... not even taking in hand the two
Sketches
Panerai has Italian origins, when the vast majority of the major brands of watches from Switzerland or France. However, if we go back to the origins of the watch, we realize that Italy is one of the cradles of the art during the Renaissance.
Cradle of the Renaissance, Florence was also, from 1864 to 1870, the capital of the Kingdom of Italy. This period marked the beginning of the collaboration between the signing of Panerai watches and the Italian Navy. In 1935, to compensate for the inferiority of the Italian fleet, the Royal Navy had the idea to develop new machines of assault, making for its management to some carefully selected officers and NCOs. The Ministry of War even requested to consider a light clock especially for divers.
Since 1938 and under this order, begins in the world of watchmaking, designing and supplying the Italian navy watches good bill, good reading and resistance to water. Not surprisingly, it is Rolex who is responsible for producing the boxes and movements which form the basis of he first Radiomir 1938. A few years later Panerai Luminor will build to significant improvements in all aspects, and in 1993 the company relaunched creating not only a new dimension in terms of size is concerned.
Radiomir as reality's first foray into the manufacture Panerai watches. With a box-shaped pad and spindle-shaped profiles, along with a screwed crown and back covered at the outset, the needs of those who complained of a clock of military-grade reliability and water-resistant qualities.
In 1998 Panerai makes a reissue of that model, currently interest is detected by Panerai raise a claim to the Radiomir, until not long ago relegated to a size (40 or 42 mm) just keeping with that of the original. The series "G" (2004) and "H" (2005), short of historic dimensions estimated at up to 47 mm, are concerned to seek the beautiful Black Seal (black label), 45 mm in diameter, with reference PAM 183 (with small seconds at "9")
The box
The box, polished steel (316), consists of bezel, case and screw back, sapphire crystal provided on the front and back (shown). On the back, at every turn, brings the numerator and Gen.
100 Sealing in meters
H0134/1500 Ringtones year of manufacture with no unit and total units manufactured
OP6644 No internal reference panerai
BB1137547 Order No. manufacture of this watch in particular since 1997 (Richemont Group)
Its form strictly respects the contours of the original 1938 design, with screwed back and crown. A screw down crown on a manual winding watch Panerai has complied with historical accuracy. I read somewhere that the forms of this box are "sexy" the most beautiful known way of "squaring a circle" in three dimensions.
The lumen area and
It consists of two overlapping spheres "sandwich": the first of which has drilled rates, that show the luminescent substance contained in the lower disk, giving it a different readability, as the viewing angle from which query time, all under a sapphire crystal domed. The solution "sandwich", although the data and clock sources, it was the first to be used as such amendment was prompted by complaints raised by the first readability divers who used it. To overcome this difficulty, Panerai developed a sphere (which would serve as a basis for having cut rates) with different chemical compounds, so that luminescent had virtues that improves the readability, including the radio, hence the name of the clock . Currently contains Luminor, substance tritium-based light containing a charge much less radioactive than radium bromide Radiomir.
View as shining with the modification of the master Ziggy. Gen. spitting (photos taken during the day on a black background)
[Needles
The matte black needles (like the sphere) but luminova equipped, giving it good legibility under any lighting condition. Corresponding to the second, located at the "9" in the form of "torpedo" and a size along the contours of the sub dial at the turning of the same dimensions as those for the index of "3" , which gives the whole a great balance.
FMALDONADOG
82
The crown
With good size (7 mm) and taper and threaded it perfectly for a manual winding watch, is signed and provided, therefore, the corresponding brand logo on the front. With his stripes, his grip is excellent and is all touch and sound delicious.
Handles
The so-called "towel", but were originally welded to the body of the box, now are properly bolted to it, retaining its original design, the practice can be unscrewed and separated (in two parts) In order to allow placement belt "conventional" wide 26 x 22 mm. These fine solid steel rods are stronger than the strongest of the conventional pins (holes) when attaching the strap to the box.
Size
Movement Swiss Unitas 6497 manual 21.600bph. With such fine tuning "gooseneck" and the inscription on the bridge of "Officine Panerai," observed no differences with Gen. In the hand can appreciate the beauty to see the caliber seen through the sapphire crystal back and see reflections when the light falls on it ...
LA Correa
In this case, brings an original strap calf leather, light brown, 26 x 22 mm, of superb quality. Finished in a buckle type ardillon based aesthetic of the early years when the Radiomir was the first birth.
Conclusion
A watch that costs us see at first glance but many integers wins when we have in hand. Elegant, distinct, easy reading, with a history that precedes it in the end .. dress a unique clock with its own personality.
Thanks for reading, are of what not to swallow this billet ... ..
* Personal Insights and network data.
Debre
210
Beautiful pics in this thread too! :thumbsup:
This review confirms what I already knew....I must get me one! :)
