PAM604 de-casing help needed - UPDATED!!
panermaniac
3,260
47
Canada, but in Hungary... for now
Hi guys, I'm a little concerned about the +10 seconds. Should I be?
PolonusTM
2,131
711
when you get it - it will be always something different after such a long trip. easy to regulate. Works fine with low beat rate error which is nice.
Ko67
1,223
118
Such a short reading in a single position is of very little use in predicting performance of the watch. Good amplitude and low beat error indicates that the watch is in beat and that power is getting from the mainspring to the balance as expected. I would not be either worried or encouraged about the +10 as it is meaningless for such a short sample time.
ALE7575
Section Mod
19,846
423
I agree with Polonus. NO worries
ALE
trailboss99
Head Honcho - Cat Herder
Administrator
43,664
17,860
The most important thing is the nice clean trace, no rough pallet stones, no bent staff etc. That, sir, is a good 'un.
Langirt
157
What are the min-max acceptable figures for beat error and amplitude?
panermaniac
3,260
47
Hi all, I received it and its gorgeous but I'm trying to de-case it, but I have run into trouble.
Case back off
Crown and stem out
3 movement holder screws out
movement doesn't budge???
What am I missing??
PolonusTM
2,131
711
it is probably front-load. You need to remove bezel to access dial etc.
mysterio
9,794
866
That's what I was thinking (dreading). How would I go about confirming it?
Are there any tutorials about it as I've never attempted it before?
Maybe one of the modders can help you out. The PAM127 is a front loader and I remember a member taking a hammer and knife (I would presume a case knife) to the case to remove the bezel. But better if one of the modders explain it (and best with pictures). :)
PolonusTM
2,131
711
The construction would be like SF Pam 425 - so bezel is being kept by plastic ring. Case knife would do. I removed 425 bezel by use sharpened plastic piece you use to play guitar with (I don't know English name for this)
mysterio
9,794
866
It's a guitar pick. :)
