PAM448 movement issue
paneristi351
73
Recieved my PAM448 (super clone P3000) from TD last week. The overall building is very solid.
However, after two days worn, I found the watch will randomly loss time 5~30min in daytime, while keep stable as lay in watch box over night. After detail check, I found the root case is the minute hand will sunddenly "jump back" as encounter little shock such as arm swing and quick walk etcl. I think the movement must have severe intrinsic flaw (gear wheel match or assembly error)
The TD can only offer ship back to examine.
Dose any one has suffer same issue in Rep world previously or has any repaire lesson learn for sharing?
PolonusTM
2,130
711
If only minute hand jumps while hour hand is on time - then I suspect the minute hand needs to be pushed down on cannon pin to maintain good grip.
paneristi351
73
Thanks for the input.
Only minute hands jump. The center pin is flat, dose it mean the minute hand in right position?
spankster23
1,266
27
Texas
Polonus is saying that, maybe the minute hand is loose on the cannon pinion. Movment needs to come out of the watch and the minute hand properly seated on the canon pinion. Sometimes the hands get loose, and or stretched.
